| Site Admin |
Hi all,
Latest version - Beta 10.72-025 (November 29 2025)
Latest version - Beta 10.72-026 (November 29 2025) - Release candidate, without FFmpeg/R128
KNOWN ISSUE: macOS version does not have a valid code signature and might not work if you don't have internet access. Our old signing certificate expired and the new one doesn't work. No Mac versions will be released until this issue is solved.
Downloads
Windows:
Pi (ARM Linux) 64 bit:
Pi (ARM Linux) 32 bit: (still building)
Changes/bugfixes
- MicroMPX ^C behavior
- R128 misbehaved completely when FM with composite clipper was enabled
- Updated Adaptive Bass Monster presets (slightly less mid-highs, slightly less extreme highs pullup compared to rest)
- Updated presets
TOP PRIO TODO's
- STB add selection of input sound cards (main/backup/AES67/...)
- STB remove many sound card and CPU settings, keep diversity delay.
- STB: Cleaned up warning/question confirmation list
- ABM: Check Auto EQ
- Wouter make 1 STXtreme video + 3 video's + 1 screenshot for Pi video - see vimeo
- STB copy the L/R audio to the LQLL output.
- STB STO's
- STB: Map POWER FAILURE GPO to an error in the web interface
- STB: Remove writing to the POWER FAILURE GPO - also in the image. - Not done for image, let's wait if this causes problems on the real hardware
- STB: Sync between FM and HD out breaks when switching presets
- STB: Make sure Adaptive MB runs in 16x mode
- STB: Why is CPU usage higher than for SA? -> Reduced CPU usage by reducing infinite screen refresh speed to 20fps
- Check if lower prio's get rid of glitches - yes, partially, higher IRQ prio helps too though. -> Not needed, increased AES67 read buffers.
- STB: Some presets are too heavy, why? (Thrust Vector, Arena Clarity). - They just use a lot, still well within bounds, so ignoring this for now.
- STB GPI's. (1 GPI is for EAS)
- STB sometimes crashes on startup (since Friday?)
- STB: Make CPU bars not orange this quickly. 65% is fine.
- STB Maybe figure out minimal reliable latencies, but we can do that later as well.
- STB Watermarking and licensing.
- libMicroMPX DecoderTSWrapper function always returns false even when it returns a valid packet
- VST keyboard input in RadioBOSS since 10.41 https://forums.stereotool.com/viewtopic.php?t=35264
- BS412/R128: Make them usable simultaneously - LATER
- BS412/R128: Why does original BS412 compressor not respond immediately? - LATER, not a new issue. Bojcha's test track with his settings goes down too much at 50-55 seconds. Probably because it goes down too slow at the start. - LATER
- BS412/R128: Support parallel compression? - LATER
- BS412: Verify how well compressor mode works - LATER
- Bypass RDS UECP character re-encoding https://forums.stereotool.com/viewtopic.php?t=35262
PRIO TODO's
- MicroMPX: Better encoder analog input peak determination for encoding and warnings
- MicroMPX: Highs RC tilt influences output MPX scope on decoder - it shouldn't.
- SST beeps on MicroMPX (no license check)
- Make it possible to set IP address via web interface on Pi image
- List of customers (name, country, licensed features, price, date, invoice #)
- SFN graph (block diagram). Leo Bodnar feeds Nautel transmitter, ST 2x, explain that it locks amplitude, frequency and audio timing.
- Run MicroMPX as a service in Windows
- Magic RDS RT+ doesn't work
- Create single persistent Python version of SNMP monitoring tool for Pi SD card image BUSY
- MicroMPX monitoring tool
- Test SDI
- WatchCat: Add ffmpeg to installer, and remove need for scripting for that. Also make that a free option.
- MicroMPX: Add simple UDP packet forwarder. (what about RIST?)
- MicroMPX: Allow telling MicroMPX which ports to combine for the same stream (v5? maybe unique stream id in rtp?)
- MicroMPX V5
- Add EDI support! Remarks Peter van Ak... AAC block size 960 (FDK code patch), EDI headers, later EDI metadata via input.
- ShoutCast V2
- Disable chkdsk in boot, see my reply email from 3/Apr/2025 14:43. See also https://chatgpt.com/c/6800ad26-a3c0-800 ... a34fea7465 to prevent this from happening.
- NEW FM CLIPPING IDEA: Pre-analyse highs loss and compensate for it, to allow more snappy highs though on FM
- Top-of-hour ID in MicroMPX and ST
- EAS in MicroMPX and ST, ask Josh
- JSON interface documentation, plus documentation of UECP mode, and best practices for creating a new preset, and simple explanation about how to modify existing presets.
- Auto Pilot
- Preset descriptions. Separate categories. Filtering for specific formats, maybe with checkboxes per preset to set those.
- Low bitrate AAC processing (Norway etc)
PRIO BUGS:
- Mac signing
- VLC input can loop old audio: https://forums.stereotool.com/viewtopic ... 864#p78864
- Keyboard input issue in 10.70: https://forums.stereotool.com/viewtopic.php?t=35234).
- Check: Bug report that channel linking is broken in 10.70: https://forums.stereotool.com/viewtopic.php?t=35227
TODO's (build system)
- Mac signing
- Bojcha: Something is wrong with final limiter mode (part of final clipper). See Discord August 26 2025
- Check email delivery issue
- VST3 MSI installer for Windows with silent mode - https://www.youtube.com/watch?v=kn4aPKgHHIM
- Renamed .so files must be patched with patchelf --set-soname libStereoTool_noX11_arm64.so libStereoTool_noX11_arm64.so
- Suppress "A piece of audio was missing" message from constantly popping up.
- Show red error text (PSTATICTEXT with SetError(true)) above Input 1 + 2 settings when backup is running. See SetBackup call.
- MicroMPX: Decoder hangs when sending multiple RIST streams to the same port number, and then stopping the one it's listening to.
- MicroMPX: Add very simple file player with pilot/RDS. Page with backup player settings (MP3/WAV) + RDS settings. 1 extra tab in web interface. Maybe add uploading, support very low speeds. Play from USB (D).
- MicroMPX: Make both output channels separately adjustable
- MicroMPX: Add option to add phase inversion
- Mathijs: Check Stokkemask stereo effect, can we reduce that? BUSY
- Attempt to remove mallocs in webserver code: ServerWorker::tryWebsocketHandshake, excludeWarnings
- Attempt to reduce mallocs in preset saving code
- Web server: Close connection if it is not used for a long time, or increase max connections. Someone has connection issues with too many windows open: https://support.thimeo.com/scp/tickets.php?id=11202
- Check lib-untracked origins
- Where do we put the build scripts (pscp, tar, plink)
- 10.51: ABE version does not have ABE colors or login accounts - Wait for feedback, override default colors (and maybe saving them)
- Clara HW test
- Optimization: Exchange latency for quality for STB
TODO's (not related to build system)
Tom:
- Multiband load preset can make number of visible bands go up/down constantly
- Full screen mode is saved to presets! Should not.
- iPhone 15 misses labels in Chrome
- DcWave add delay, maybe make it work same as Wave, because now it's displayed unsynchronized with everything else.
- Usability: Maybe redesign how RDS now playing text inclusion works?
- Usability; Show streaming data in GUI (artist, title, song)
- Multi-instance: Tray icon should not show instance 0, and ! if there's any error
- Multi-instance: ! in overview if something is wrong
- Tab navigation should show abbreviated texts
- Don't center titles in narrow mode
- ST-Enterprise: Copy presets to other instances
- Compile ST to webassembly?
- More different meter colors.
- SCStreamingOutput is now a combination of VLC and builtin streaming, messy.
- Split presets into built-in and user
- LADSPA (or LV2) plugin? For ffmpeg, among others. Or inside ALSA(?).
- Load presets via JSON API
- Arrow in tiny info, maybe add sample rate? Maybe add optional element if there is space to bandpass display.
- Maybe add option to select what to see in meter bar
- MacOS: GUI doesn't move unless the window size is changed (VST2, VST3, stand alone not tested)
Hans:
- STXtreme extra instance 8-character code registration doesn't know the file name where to store the license key.
- Check if UECP RT A/B flags are handled correctly. Mail Matt Paton 18 jun 8:50AM
- MicroMPX: Jeroen: op jullie pi image kun je de NIC niet kiezen, alleen default of loop
- Mathijs' feature for new preset! Needed for YourSafe. Auto EQ after AGC would be nice to test
- Export EXPORT.GUI list including parameter enum names, and include in libStereoTool zip file.
- MicroMPX: Show warning if MicroMPX is enabled in ARM build at 44.1 kHz (doesn't work).
- MicroMPX: Add PWARNINGs for errors that need a popup, for example entering wrong license key
- Build: Test: Stereo Tool Pi CPU usage
- Build: Add LInux (intel/ARM) VST3 builds
- Investigate glitches when using Generic plugin in high CPU mode (could be on the caller's end)
- New compressor: Add pre-compression clipper to reduce effect of loud highs that will be masked by clipping/limiting
- Check if median levels are correct, may be displayed at wrong level
- SCInstance 848 mutex can hang (Mac, with insane CPU load)
Overall:
- URGENT: Socket error in libShout, followed by not reconnecting.
- Bug: When a LiveWire channel is selected in the pulldown, but nothing is detected anymore, after restarts it overwrites the channel that's selected in the fill-in field next to it.
- NEW COMPRESSOR IDEA: Maybe set a minimal speed, easier to use than speedup on drops. Nice curve into it. -> Probably not needed, issue was caused by Casper and that's fixed now.
- Is some Auto EQ-like behavior in the new compressors useful to prevent too much sound adjustment? Or should we just make the bands wider? -> "Soft linking" fixed this. Maybe something is needed for R128?
- Photos to travel site, and update it
- Allow Auto EQ after AGC (or better: Let it output a sidechain with only weakening of levels) (Mathijs)
- MultiVOC Jack version more than 2 channels
- MicroMPX: On our SD card image, it doesn't show the NIC for ETH0 in the pulldown menu - why??? Works fine in other images.
- Check if input affinities are set
- AES67 Do we want to also support the system clock, including any offsets that are applied to it? Probably not?
- File player for top-of-hour legal ID (for both MicroMPX and ST)
- UMPX TESTS F
- MicroMPX v5: RTP
- MicroMPX v5: RIST
- MicroMPX v5: Improve quadrature encoding for very clean signals to avoid rounding errors in peak level detection.
- MicroMPX v5: Add GPS timestamp to encoder library API so others can use our encoding
- MicroMPX v5: Email joost 2
- MicroMPX V5: Add partial keyframes for faster recovery without resending everything
- MicroMPX v5: Re-check if 38.4 kHz is the ideal sample rate, since we never want audio above 16.4 kHz anyway!!!!!!!!!!!!!!. Can we use a frequency such that no LPF is needed (eg 33 kHz)?
- MicroMPX v5: Check GPS calculation error (inverted atan, //TODO in GpsSyncedSoundcardOutput line 494)
- MicroMPX v5: Maybe encode highest audio frequency
- MicroMPX: Better way to tell it which ports contain the same signal (currently must use same port number)
- Streaming input on Pi.
- Directly after new build system: Put PhoneBooster in VST plugins
- Directly after new build system: Add VST Linux support
- Directly after new build system: Add AU support
- Check reported "Socket error" in output stream. Apparently new in 10.50 but I don't know if that's true. https://support.thimeo.com/scp/tickets.php?id=9990
- Streaming blocks if now playing file drive is unreachable (10.21): https://forums.stereotool.com/viewtopic.php?t=33962
- Linux: "Full screen" mode - after closing the software opens without a GUI. Workaround added, real fix needed later.
- Potential AAC streaming issue on Pi: https://forums.stereotool.com/viewtopic.php?p=77926
- Create C++ version of SNMP monitoring tool for Pi SD card image
- K Black Pi RDS2 issue - fine on Windows, potentially ARM code error
- Bug: HD output level is reduced when using BS412. Has been this way forever...
- Add libVLC support to Linux/Mac builds (for OS parity)
- Pi image: Check Pi memory patch
- Check VST3 crash on Mac TOM
- Check VST in Auditon on Mac TOM
- MicroMPX multicast issue directly after startup
- MicroMPX: Export the control signal that would control when the backup player becomes active to the JSON and library outputs so GPO's can be coupled to it.
- Web interface KoekError display: Add last error time to web interface. But NOT for MicroMPX, because there the time is already part of the error message - or change that, but identical messages must still be logged separately in that case.
- Output streaming via libVLC is broken; it does not detect when there's no connection, and does not detect connection loss in VLCGetBuffers. So it does not properly reconnect after an error.
- Check Hard Limit behavior (Bojcha)
- Add + button for streams, to make page less crowded
- MicroMPX: When signal comes back, backup player stops and silence is played, can be 14 seconds if that's the buffer size.
- Vorbis: Add sample rate; if we're running at 192 kHz that's also the stream sample rate, should be 48 in that case.
- MicroMPX Add way to set IP address - but how??
- Re-enable MPX demodulator settings in Stereo Tool (MPX Tool-like)
- STXtreme 5 FM instances doesn't work if more than 2 are set to latency 128. Do more measurements and figure out what the limits are.
- STXtreme: Implement smart glitch detection INTERNALLY so we don't need to run external tests all the time. Maybe we can already see it!
- STXtreme multi-instance hiccups system Matt - why?
- STXtreme: Audio seems fine even though buffer display shows that the buffer is very low.
- MicroMPX: Add/modify JSON parameter that shows total used bitrate to include RIST, plus number of RIST clients.
- MicroMPX: Add way to set IP address of hardware
- Multple streams: Support different metadata??
- MicroMPX decoder: RIST: Figure out way to get rid of RIST delay, or how to sync with non-RIST and how to specify RIST vs non-RIST delays - LATER
- MicroMPX decoder: RIST: How to handle RIST delay in combination with GPS
- Would it be possible to make an R128 measurement there, where I can set the measurement period for a sliding window between 1 and about 5 minutes?
- MicroMPX: Reduce RIST overhead
- Clipper + Hard Limit makes the spectrum dirty, mainly for pure sine waves - but why?
- MicroMPX library: umpxDecoderDecryptAnalysePacket may try to decode a packet while internally a packet is already being decoded, causing threading issues.
- MillingBroadcast's MicroMPX speed issue with encoder in Stereo Tool on Linux: https://forums.stereotool.com/viewtopic ... 454#p77454 - Waiting for feedback
- Silence detector in ST with email/SMS?
- Bojcha (via Discord personal chat with images): Clipper (measured HD out, no pre-emphasis) has HOLE between 5kHz and 13kHz about 0.4dB. Only way to fix it is to set Highs clipping from +1.51dB (default) to +0.95dB. He says it sounds better too... (less gaps due to highs, not less highs)
- MicroMPX: Add GPS support for decoder without NMEA. That's how others do it - they just use the timestamp in the packet as the time of the closest 1PPS pulse. Will simplify the hardware!
- MicroMPX: Silence detection in MPX is used to switch between studios! So reporting levels is really necessary.
- Mathijs: Als je de AGC in Matrix mode gebruikt (trouwens voor MB hetzelfde denk ik), dan wil je eigenlijk channel linking gebruiken om te voorkomen dat L-R heel extreem bijgetrokken wordt tov L+R. Alleen: als dan de hoeveelheid stereo content flink toeneemt kan het zijn dat L-R de L+R mee omlaag trekt, en dat wil ik eigenlijk niet. Dat gebeurt sneller als je ook nog die "Stereo boost when AGC is below threshold" setting gebruikt. Zou fijn zijn als die channel link maar één kant op kan werken; dus dat L+R altijd vrij kan bewegen en dat L-R daar aan vast gelinkt hangt
- Vinyl bass rumble removal
- 32 bit CortexA53 old GCC version for GA
- Can we use USE_COMPACTED_STORAGE by default? Would save a lot of memory.
- MicroMPX doesn't show EF mode error in Stereo Tool plugin version.
- < 150 Hz mono to remove rumbly on vinyl.
- Insert points: Via the sound card to outside and back? Or via VST's. To enable adding effects.
- Vinyl click detection and removal.
- Report that VST3 on Mac crashes on startup
- Sound cards: Add VLC to input 2 for backup - but that requires a fix for when the stream drops out.
- Website: Write description of how to set up ST + MicroMPX, seems to be difficult for some people to find.
- Add loading presets via JSON (nrk)
- Finish US pricing, update prices.
- MicroMPX overview app
- When sound card/stream recovers after error, clarify current message which appears to indicate that it's not streaming at all.
- Remove Stokkemask Clipper?
- Remove Simple Clipper from STXtreme
- Phase Delay isn't disabled at low latency settings, causing extra delay.
- MicroMPX GPS: Extreme amounts of logging when GPS data doesn't come in due to bad antenna. Causes disk to fill up in a day, so the logging cleanup also doesn't help.
- LiveWire 48 kHz FM output doesn't work with ASIO
- Streaming: Add FLAC support
- Test SDI
- GUI: Sound card buffer slider behavior
- Verify that inputs 1 and 2 have separate tilt corrections.
- Analyzer
- Mac AU plugin should be easy to make now
- Create small program to send UDP or TCP commands for UECP. Maybe even real UECP commands... Could be the start of a new product
For now, ncat works (example: echo PS=Hello | ncat 127.0.0.1 4001), see https://nmap.org/download.html#windows
- I/O: Add file input (and output?) so we can use files as backup material. Maybe both let it run all the time or make something like in MicroMPX that only plays when needed and pauses in between.
- I/O: AES67
- MicroMPX: Make readSlidingWindow smarter; only copy if necessary (lazy).
- MicroMPX V5: Add L/R peak levels to encoder and decoder libraries.
- MicroMPX V5: Simplify header structure
- Add test tones to check phase and level issues for FM, like in old calibration.
- Fix stepping of sound card buffer sizes (without control/shift should be 1, not .1 or 10).
- Add RDS2 slide shows
- Check report: Generic plugin crashes on mono input
- GUI: Don't show 2nd channel for mono processing
- Delay issue in MPX display; not synchronized with the audio.
- Overview screen password protection: How should that work?
- Overview screen: Error should be shown here.
- Mono bass for HD cannot be enabled without enabling the other "Reduce stereo" settings as well; needs to be split off just like for FM.
- MicroMPX: Somehow detect and report number of incoming streams
- Do something to draw graphs even without audio
- Pragma messages: Check and remove where possible
- Check BIMP meter bar; dynamics section MB on/off removes top bar
- MicroMPX: Add error checking for IP addresses, don't open if the address isn't complete. (Maybe wait for ENTER? - Web interface).
- Improve sound card error messages on STXtreme
- MicroMPX: “umpxDecoderGetStreamFeedback()”: the signal lost counter in umpxDecoderStreamInfo seems to be stuck or sometimes not to count up when there is no input (with pilot generation active, internal sync turned off). I can’t rule out the problem is on our side, but it was working before and I think we did not change anything handling the umpxDecoderStreamInfo.
- Streaming must read data from files from a separate thread, https://forums.stereotool.com/viewtopic.php?p=75718
- Can we add an automatic gate for Blue Monday? Detecteer harde tikken die even hard zijn als input maar toch steeds harder worden en te hard zijn.
- STAMP license error message is only visible in the native GUI (which doesn't exist); how do we show it in the correct GUI (the one in which the button was clicked)? Same question for overview page.
- DHD: Remove logging, probably.
- DHD: Add FM Professional to purchase options on the site.
- Fix Declipper issues reported in https://forums.stereotool.com/viewtopic ... 4&start=30 and on Discord
- Restart when sound card does not work is not working anymore
- .st.gui_override does not survive firmware updates in SD card image; needs to look in root directory.
- AES67: If a LiveWire port is selected under "Device" but nothing is detected there, that port number overwrites the active port field on preset loading. The pulldown itself cannot be changed if nothing is detected.
- Advanced Clipper: MAYBE make a filter that limits how much bass mids and highs protection can remove at the most. Can be done later.
- AGC: Most likely we'll also need to change the release behavior compared to the compressors.
- AGC: Bojcha: Some other stuf really needed, - startup level - return to platform - gate after agc (please) - some sort of compressor or some protection for bursts like on old AGC - why freeze is not fully freeze (there is delay)
- MicroMPX: Run as service?
- Loading a Stereo Tool preset on PiMP also sets things like whitelist, blocking access.
- Make RDS/RDBS selectable or something, independent of 50/75 us pre-emhpasis.
- New compressor: Matrix mode: Limiters work on L+R and L-R, instead of L and R. That's probably bad.
- MicroMPX: Allow RDS settings in library?
- PEQ in MicroMPX FM output?
- Sensitivity scrolling vs sliding
- MicroMPX: Check pilot cleanness in decoder if pilot frequency is slightly off (19005 Hz).
- Also, I notice when adjusting the buffer, there's no way to adjust by 1ms. There's 0.1ms (CTRL), 10ms (SHIFT), but it doesn't go by 1ms when no modifier is held. It would also be very handy to have the Synchronize with HD slider in between the HD and FM output cells instead of hidden in the More FM Output Settings.
- Reset skin, and other things (basically anything that can be loaded?)
- Pi: Make network settings changeable via web interface.
- Startup delay on MicroMPX?
- Update LiquidSoap links
- mndxer1049: Better Natural Dynamics section with WB dynamic detection
- mndxer1049: A very transparent, C-Level like new AGC design
- mndxer1049: Auto Stereo Pilot
- mndxer1049: Maybe: A button for putting all CPU settings at the maximum value and turning on all CPU intensive settings that only improve audio, but take quite a bit of CPU load. (ex. sliders like ‘Quality (increases CPU load)’ under DeClipper restoration, “Strictness (CPU)” and “Leif’s highs gap protection stages (CPU)’ under Clipper just to name a few of these ”CPU sliders” I’m referencing.)
- Display bug in MPX display (weird spectrum glitches that occur occasionally)
- Add streaming output to VST version?
- In the audio input section I'd like to see options for speakers to be included without having the need to use virtual cables to route. I was thinking something similar to Rocket Broadcaster. There's input for mic and separate application source.
- MicroMPX decoder: High frequency tilt correction is performed BEFORE data is collected for display, looks like overshoots.
- Auto pilot
- Redesign ND dynamics detection
- Maybe add some frequency display to MPX display. https://forums.stereotool.com/viewtopic ... 16&t=33720
- Add numeric displays to ITU and MPX levels in GUI https://forums.stereotool.com/viewtopic ... 16&t=33686
- Insert/delete bands in multiband compressor, instead of (like now) just having to add/remove the last one when the number of bands changes.
- Non-phase linear: For example https://github.com/nxsEdson/Butterworth ... rworth.cpp
- STXtreme errors when reusing sound card
- STXtreme set shared sample rate (instances can set different sample rates)
- Azimuth affects highs!!
- Ratio slider smarter steps (1.1, 1.2 etc) - MattL
- Meters: add separate FM/HD output level displays.
- New compressor and matrix mode?
- Add 0.05 precision to parametric EQ and attack/release multipliers
- RDS: Add settings for how long texts are shown or how fast to scroll for UECP inputs.
- AES67 generic mode: Let people enter IP address directly.
- MicroMPX: Show temperature
- MicroMPX: Show status per incoming port
- Links: ID_GOTO must be a PLink that points somewhere.
- Dynamic speeds: License detection only works after audio has been running, that's not ok.
- When audio has run after a settings change, trigger a parsetChanged
- Time offset on STXtreme, for RDS (also for ClockTime!)
- New GUI: Support smaller monitors (smaller default size, especially for VST). Contact near05.
- Export presets from web interface needs filtering, just like from native (so the code is there! Just reuse CopyPresetOm*).
- Mac: VST2 sizes
- Mac: gavinmcgrath: "Intel MacOS 11.7.3 in Wavelab 11.1: Blank screen." https://forums.stereotool.com/viewtopic ... 407#p73407
- Stand alone RDS decoder
- CPU usage of REFRESH_ENABLED is high, maybe use local array.
- PDcWave delay not set
- WatchCat: Keep track of when files have been processed and ignore them, but don't move them. (DropBox)
- WatchCat: Can we include ffmpeg and lame?
- Add latency wizard?
- setFaultyValue for text boxes for wrong passwords for example - check with Tom how to use
- Can we enable FM Calibration in "Ignore high frequencies" mode? Not easily
- Add check for running ST multiple times; make switchable if we want to allow it or ask if you really want to start if it already runs or something.
- Matt: Pre-emphasize highs slider needs to get a clearer description! Something with avoid overshoots. Basically a sidechain EQ. "Add highs to sidechain".
- Matt: UECP must be more easily accessible, too deep now.
- Matt: FM+AM
- New I/O framework: Add extra latency to plugin input so the input 2 to LQLL can be instantaneous.
- Check Bojcha's good bass HPF settings (18200 Hz, ignore high frequencies, 48 kHz, 35 Hz HPF)
Latest version - Beta 10.72-024 (November 28 2025)
Downloads
Windows:
Changes/bugfixes
- Added version number to Windows binaries again (disappeared in 10.60)
- D added dynamic product names, read from file
- Product name display added to system info
- Made meter bar bigger in web interface, and threshold deliminators more clear to make setting up MicroMPX encoder level easier. The bigger meters also look better (to me at least).
- Snooze MicroMPX encoder level warnings, currently complains if above 100.0% or if below 99.0% and keeps nagging. Or some other solution to make it less "loud". -> Leaving as-is for now, it's just a flashing triangle.
- Fixed MicroMPX TTL display issues
- Finished all translations and fixed special characters in language dropdown.
Quote: Latest version - Beta 10.72-023 (November 27 2025)
WARNING: BETA012 contains a lot of risky changes, mainly in the sound card I/O code.
Downloads
Windows:
Changes/bugfixes
- MicroMPX: Increased encoder USB delay range; Leo Bodnar GPSDO seems to need around 600 ms (but above 500 ms doesn't work, 500 is close enough for now)
- libStereoTool: Added stereoTool_SetRdsBitCallback function to externally feed RDS data
- D hide loopback checkbox, always on
- D hide virtual sound cards - TEST
- Error messages have ? as version number
- Quick Adjust: Maybe add single slider for band linking
Latest version - Beta 10.72-022 (November 26 2025)
Downloads
Windows:
Changes/bugfixes
- Fixed crash when recalculating font sizes in BETA021
- MicroMPX decoder: On some devices, obtaining a loopback lock could cause the 1PPS pulses to be no longer detected, making it impossible to obtain a GPS lock. Solved.
- Fixed clear error buttons in web interface, that often didn't work
- FFmpeg: Fixed Linux pipe names
- D fix GPS
- Q fix crash - not on our end
Latest version - Beta 10.72-021 (November 25 2025)
Downloads
Replace links with 1072-021
Changes/bugfixes
- Phase Delay: Protect output so it can't trip other things in the chain when values are changed
- Stereo Reverb could have negative distances
- MicroMPX: HF tilt does something weird at low values, check with high frequency sine. - Internal calculation exceeded Nyquist frequency; now filter is disabled close to or above Nyquist, typically around Highs Rc below 0.220.
- MicroMPX: Don't show MicroMPX+ license warning for each packet (causes count to go up) - Does not reproduce here, are they using a very old version or wrong settings?
- LQLL block size is only availalbe under Resource usage, not under LQLL settings
- MicroMPX: Why does white noise trigger RDS? - Fixed, added tracking of RDS quality using variance of peak levels.
- Streaming hangs if now playing info is read from a remote drive that hangs - causes timeout followed by login errors. Now reading data doesn't block streaming anymore.
- FFmpeg tag input reader/parser, and error popups
- Added translations that require different fonts (Chinese, Korean, Thai) - 64 bit only, and not on ARM builds
Latest version - Beta 10.72-019 (November 20 2025)
Downloads
Replace links with 1072-019
Changes/bugfixes
- FFmpeg protect against writing too many 0's at startup, which fill the output buffer so far that we cannot write actual audio to it anymore. Reproduce by sending too much silence at start.
- R128: Added an extra setting that raises the maximum compressor attenuation floor on speech, makes speech about a dB louder, very close to target now.
- R128: Something goes VERY wrong if FM output is enabled, probably sample rate issue. - Changed code to always send de-emphasized normal output to R128.
- LiveWire stream detection didn't work on Linux, and kept reopening sockets every few seconds on all OS's.
Latest version - Beta 10.72-018 (November 19 2025)
Downloads
Replace links with 1072-018
Changes/bugfixes
- BS412/R128: Show external level adjustment in "User multiband compressor" mode in display.
- R128: Tweak "Level adjust after short term... speed" setting
- Enterprise: Intrasonics watermarking: Add ConsumerH8
- GUI: BS412 colors are horrible with PARAM_SHOW_DEESSER_DEBASSER enabled. - never mind, disabled for now
- Startup behavior for BS412 and slow band linking is inconsistent at startup - Added some checks, but it looks like some files were never replaced in the test run.
Latest version - Beta 10.72-017 (November 18 2025)
Downloads
Replace links with 1072-017
Changes/bugfixes
- R128/BS412: Reset measurements on target level change to avoid level dropping to silence
- R128: Why does Post Amp not work with R128?
- R128 disable LF/HF limiters that affect bass and highs, they are for BS412!
- R128: Add True Peak! And don't use TP from BS412!
- BS412/R128: Disable internal compressor when using "Use multiband compressor"
- R128: What should it do in Bypass mode?? - Nothing, disable
- R128: Reduced memory usage
- LQLL memory usage if it's not used, broke a few beta's ago.
Latest version - Beta 10.72-015 (November 15 2025)
Downloads
Replace links with 1072-015
Changes/bugfixes
- MicroMPX CortexA9 command line version uses less memory for hardware with only 256 MB
- All programs: Show a very clear error message if $HOME is not set!!!!!!!!!!
- FFmpeg input-to-output hangs on Linux (separate input or output is fine)
- R128: Add configuration of exact R128 level. Let's also give it its own on/off switch.
- R128: Find correct values for peak boost
- R128: Auto-adjust peak value to handle changes in threshold level. All settings now scale to follow threshold.
- Bug fix: Low audio levels in VB Cable in BETA011/013; MME/DirectSound devices were opened with more channels than MME/DS support.
- R128: Maybe increase effect of shorter timing intervals to boost levels
Latest version - Beta 10.72-012 (November 12 2025)
Downloads
Replace links with 1072-012
Changes/bugfixes
- Rewrite UTF-8 network name conversions on Windows
- Printing error on Windows on load library failure
- Enterprise does all modal stuff on 1 thread now
- Immediately handle sound card updates (used to wait up to 100 ms)
- Removed display of old sound card errors in buffer meters
- Sound card errors are now separated per input/output target
- Some errors now overwrite (replace) older error messages (in Stereo Tool)
- Gracefully handle situation where there are no sound cards at all
- Fixed issue in postponed LQLL initialization
- R128: Maybe increase compressor threshold if we keep dropping down constantly. For speech. - Yes, raise level if we constantly hit the compressor. In that case that also won't sound too loud. Maybe only when we reach the threshold? Or maybe even if the level is roughly constant, let's test if we can safely do that during music. To be tested.
Latest version - Beta 10.72-011 (November 8 2025)
Downloads
Replace links with 1072-011
Changes/bugfixes
- Glitch occurred - monroe2 - hopefully finally fixed!
- STB try to create single I/O device Tom
- Command line display issue: https://forums.stereotool.com/viewtopic.php?t=35269).
- S: Add Windows-32, darwin-arm64 builds
- Multiband: Make link delay configurable. And check if the last band really needs slower linking. Maybe start with 2 params?
- BS412 via compressors - Add settings
- R128 live - Add settings
- STB GPO for 48/44.1
- STB 192 kHz internal TEST
- STB sound cards TEST
- Multiband: Is delayed band linking a good idea? Test after release build. Run torture test + Extreme - Yes, everything sounds similar or better
- R128: Reduce effect of levels close to 0 dB - Never happens without compressor, so the compressor causes all of this!
- R128: Stopped rising levels if the level needs to drop, reduced speed of rising levels close to maximum threshold.
- Sound cards: ALSA, Wasapi, KS sound cards are now opened differently; theoretically we can open as many channels as we want now. On StereoToolBox this means we should be able to open all inputs and outputs in 1 call, and have perfect sync between outputs, with ALSA!.
- 2w priority settings - see email
- D add some level offset for output gain for analog outputs - Never mind, we keep Tilt visible
- STB set audio connectors as default.
- Added automatically generated translations - let us know if you miss any languages. We are trying to somewhat limit the number of translations.
Latest version - Beta 10.72-008 (October 24 2025)
Downloads
Change links to 1072-008
Changes/bugfixes
- Updated PortAudio to latest version ("A" test) - wait for results
- Multiband: Try to use linking as it was before, but with delayed effect, where we only delay the amount of level drop instead of control signals.
Latest version - Beta 10.72-006 (October 22 2025)
Downloads
Change link to 1072-006
Changes/bugfixes
- Bug fix: Multiband compressors in matrix mode caused weird hum on channels above channel 2 (5.1, 7.4.1 audio etc). Matrix mode is now disabled in those modes.
- Multiband compressor: Changed band linking behavior to add delays - may be better, or worse, tests needed.
- libStereoTool: Added web interface and UECP port binding for safer integration without external access to web server.
- FFmpeg: Avoid blocking during startup in input-to-output piping
- FFmpeg: Add silence insertion for dropouts for input-only
- FFmpeg: Added restart-on-errors without telling the framework anything
- FFmpeg: Add error messages/red bar error state. Maybe use libVLC display colors?
Downloads
Replace links with 1072-004
Changes/bugfixes
- Multiband compressor: Added band linking from 3rd to last to last band to prevent excessive highs.
- STB: Duplicate L/R audio to LQLL (test!)
- MicroMPX: Bug fix: Changing sound card in encoder didn't work until restarting since version 4.3.0 (released together with 10.60).
- S: Windows-64bits, Linux X86_64 and ARM64/CortexA53, and optionally later, if available, Windows-32, darwin-arm64, LinuxARM32/CortexA9
Latest version - Beta 10.72-002 (October 14 2025)
Downloads
Windows:
Changes/bugfixes
- Added Multicast TTL setting for MicroMPX
- Added ffmpeg input and output support. See the 2nd post in this thread for how to use it.
