 Post subject: Stereo Tool 10.70
PostPosted: Sun Aug 03, 2025 4:50 pm
Stereo Tool 10.70 is available!
Changes:
  • Multiband Adaptive Compressor: Added ratio linking between bands (soft mode). Sounds much warmer and less in-your-face.
  • Multiband Adaptive Compressor: Casper mode: Added escape after very extreme content. Settings is available to control it, may be needed for classical music.
  • Multiband Adaptive Compressor: Sudden Drop Protection can now work in wideband mode.
  • Multiband Adaptive Compressor: Increased range for "Make dense audio louder", needed for some songs and doesn't appear to have any drawbacks.
  • Stokkemask: Added new Gaussian formula for better and less wide shape. Sounds better, should be safe to use, but disabled by default until further testing.
  • Pre-ringing protection could cause multiband limiters to not properly control levels and sound weird (ever since version 5.00 from 2010).
  • GUI: Added visual color change between yellow and orange on input meter if it's playing backup input, to more clearly indicate that there's an issue.
  • Bug fix: WatchCat: Removed LIBZ1__.DLL dependency that caused version 2.0.17 (10.60) to not start on some systems.
  • Bug fix: Pre Amp wasn't disabed in Hear mode for early filters in chain (Declipper, Delossifier, Noise gate).
  • Bug fix: libStereoTool: Ignored plugin output level setting.
  • Bug fix: Multiband Adaptive Compressor: Matrix mode was not disabled for 1-channel inputs (plugin with mono files).
  • Updated presets.
 Post subject: Re: Stereo Tool 10.70
PostPosted: Wed Aug 06, 2025 7:15 pm
MB1 and MB2 with adaptive compression:
Under Channels:
Is Channel separation and Channel link working? I can't get it to work no matter what the setting is. It works fine in the previous version 10.60.
Constant sum seems to be working tho...
PostPosted: Mon Aug 18, 2025 8:16 pm
Under Channels:
Are you running in matrix mode, with a boost in the L-R? We did make some changes to (probably always) unwanted behavior, where matrix mode could cause the stereo separation to be reduced. That can't happen anymore, so the L-R (after compensating for the L-R boost levels) can't go below the L-R anymore. Before this change that could happen.
Other than that, I see no issues here. If this is not a matrix mode issue, can you send me your settings, and tell me exactly what to do to reproduce what you're seeing?
PostPosted: Tue Aug 19, 2025 7:32 pm
Under Channels:
load preset: Adaptive Bass Monster - Open
go to MB1 and reset MB1 settings
turn MB1 on again
change channel separation to 100%
change channel linking to 0.0 dB
change compressor type to Adaptive
result is no channel linking, according to the meters at the right.
you can also change channel separation to 0% and it will still not link both channels.
however if you load Adaptive Bass Monster - Open and just changing channel linking to 0.0 dB it will work.
PostPosted: Wed Sep 10, 2025 11:26 pm
I don't know if this is intended behaviour, but if you only use Stereotool's MicroMP and stream outputs, you only can get a pre-emphasis audio signal on your stream. I had to add a dummy HD audio output to get the option to select e de-emphasis output for the streams. The sIgnal selection pull down box at the stream outputs is not available if you do not have a "hardware" audio output configured. For our use-case this is not very handy :)
PostPosted: Mon Sep 15, 2025 7:32 pm
Hello Hans. Can you explain to me how to access the ratio linking option through the web interface using a screen reader?
PostPosted: Tue Sep 23, 2025 7:28 pm
You can find it in the following place:
- Go to "Multiband 1" (assuming that that's where you want to use it)
- Open "Bands", go to "Band interactions".
The "Soft linking" setting is the first setting in the popup window.
PostPosted: Tue Sep 23, 2025 7:29 pm
We have a massive I/O rewrite coming soon... this is "legacy" behavior, and that rewrite will likely break some things anyway, so that's probably a good moment to fix this.
PostPosted: Sun Sep 28, 2025 7:41 am
Hans, could you please add AES67 -things to Input2 too? It'd be nice to mix two livewire signals in stereotool without doing that externally. And maybe third input as a backup ;)
-Janne
PostPosted: Mon Sep 29, 2025 1:29 pm
-Janne
I like this idea too
