PostPosted: Tue Feb 20, 2024 8:12 pm
We were experiencing downtime on our output streams, during maintenance of other machines in our studio.
Stereotool version 10.21 is running on a Windows 10 pro system. We output to uMPX, HD Output to soundcard, and to a Shoutcast stream. For the latter, track data is read from a txt file on a NFS network mounted drive. (mounted to a drive letter)
When the network mount becomes unreachable, the output stream stops without any error message in the Stereotool GUI.
As far as we have tested, the HD output and uMPX output remain stable.
The expected behavior is for the stream to remain stable, without any updates to the track data. And as soon as the mount is reachable again, to compare the last track data to the current file contents, and update in case of a change.
PostPosted: Sun Sep 01, 2024 9:07 pm
hi
How do you configure sending song titles?
I put in the path to txt file and it does not do anything
Thx :)
Thank you.
