 Post subject: Stereo Tool 7.31 RC
PostPosted: Thu Sep 26, 2013 10:13 pm
Only a few small changes this time:
- Default values for Natural Dynamics were a bit wrong, now improved
- When loading settings for a specific filter, MB and ND default freqs got reset
- Bojcha's King's Fire 2 preset added
- Windows 64 bit VST version added
- Windows 64 bit stand alone version added. On new systems (2nd or newer generation i3/i5/i7, Windows 7 or 8) it uses AVX for better performance. (VST version as well)
Windows stand alone 32: http://www.stereotool.com/download/ster ... er_731.exe
Windows stand alone 64: http://www.stereotool.com/download/ster ... 64_731.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... er_731.exe
Windows VST 32: http://www.stereotool.com/download/vst_ ... ol_731.dll
Windows VST 64: http://www.stereotool.com/download/vst_ ... 64_731.dll
 Post subject: Re: Stereo Tool 7.31 RC
PostPosted: Fri Sep 27, 2013 1:09 am
- Singleband Compressor bar (after AGC) added to bottom :)
PostPosted: Fri Sep 27, 2013 2:44 pm
If you load a new preset with all information in it (I load normal settings and FM) then RDS is also changed. With Notepad+ I can copy my RDS settings into the new preset, so that's fine. Maybe an idea to have an option to not disturb the RDS settings?
PostPosted: Fri Sep 27, 2013 5:41 pm
Can you maybe please chance the effect name from the file name to a significant name? :)
File comment: The name of the effect in selection
PostPosted: Fri Sep 27, 2013 6:54 pm
@near05: It should show the correct name. Can you start it? So is your host 64 bits?
PostPosted: Sat Sep 28, 2013 7:48 am
When using a VST Rack, would you say it's a good idea when dropping in a new VST version dll, to reload the new dll and re-enter all settings from scratch? Or is it OK to drop the dll in and let the rack re-load settings from a previous version?
I usually re-enter all settings from scratch, just to be safe. But it's kind of a pain. :) It seems with this version, "Default values for Natural Dynamics were a bit wrong, now improved" implies that if I load 7.31 into a rack that had 7.30, it might use the old values?
PostPosted: Sat Sep 28, 2013 2:31 pm
Yes i can start it without any problems. but the name is not shown. i am using adobe audition cc (64 bit host).
PostPosted: Sat Sep 28, 2013 4:00 pm
It should work without re-entering! I never change the values of existing parameters so the only thing that happens when I release a new version is that new parameters may be added at the end of the list; any decent host should just take those new values (defaults) and use them. In this case, for Natural Dynamics the best thing you can do is go to Natural Dynamics -> Initial Boost, and right-click on all the "Subtract" sliders. That gives you the new default values.
PostPosted: Sat Sep 28, 2013 4:01 pm
Strange, I've tried it in another 64 bit host and the name was displayed properly. And the code is the same as the 32 bit code...
