 Post subject: 64 Bit VST Plugin
PostPosted: Tue Jun 18, 2013 6:47 pm
Hello,
today i installed the new Adobe Audition CC. But then i got a problem using the old 32 bit VST Plugins now. The whole application is only 64 bit. I tryed JBridge to use StereoTool, but i always got the error, that the plugin doesn't work.
will you be compile a 64 bit version for future use? in all new versions, all dlls have to be 64 bit.
Thank you in advance!
 Post subject: Re: 64 Bit VST Plugin
PostPosted: Tue Jun 18, 2013 11:43 pm
Good one. I need to setup a 64-bit development environment first though... And I think there's one place left in the code that needs to be fixed to run in 64 bit mode (a year ago there were dozens, I've been cleaning up a lot lately :) ).
PostPosted: Wed Jun 19, 2013 12:31 am
Why not standalone?
PostPosted: Thu Jun 20, 2013 10:27 pm
...and make sure that it allows the use of the latest compiler and IPP libraries... ;)
PostPosted: Wed Jul 31, 2013 10:08 pm
+1!!!! highly needed
PostPosted: Mon Sep 23, 2013 5:32 pm
64 bit stand alone version is running now. Will build a VST next. But I'm also looking at enabling AVX which - on newer CPU's - should give a considerable drop in CPU usage. I need a newer compiler for it though which until now always gave a big rise in CPU usage. Will have to see where this leads :)
PostPosted: Tue Sep 24, 2013 1:45 am
Ok, I still have to search for a good 64 bit VST host so this is untested:
http://www.stereotool.com/download/vst_ ... ool_64.dll
Edit: Kinda tested it in Reaper and seems to work fine. :)
PostPosted: Wed Sep 25, 2013 6:02 pm
It works without any problems in Adobe Audition CC. The performance is much better then in jBridge! I attached a ScreenShot.
What's about more then 2 Channel Support in the Plugin? I think you wrote in the past, that you add multi channel functionality. In the Channel Mixer i see only 2 input channels. Maybe you can also pass-through the sidechain channel
File comment: The Channel Selection in Audition
File comment: The Plugin in Auditions
