 Post subject: HTTP Commands
PostPosted: Wed Mar 04, 2026 10:46 pm
Hello: I have a question. Is there still a way to change, activate, or deactivate parameters via HTTP (not a GUI)? I saw a post that mentioned how to activate and deactivate RDS TA using http://localhost:8080/121=0 (changing 0 and 1).
I've tried it, but it doesn't work.
More information on this would be greatly appreciated.
Regards.
Audio Processing Test
((( RadioFM )))
 Post subject: Re: HTTP Commands
PostPosted: Thu Mar 05, 2026 12:01 am
What you want are commands via the JSON interface, and the documentation for it can be found under the MicroMPX documentation here: https://download.thimeo.com/MicroMPX_manual.pdf
Gemini says this about the JSON Command Syntax:
The general syntax for sending a command to a parameter (e.g., parameter 121) is:
http://[IP]:[PORT]/json-1/list{"[ID]":{"new_value":"[VALUE]"}}
For parameter 121 (which typically refers to SCA1 Enable in Stereo Tool):
To Activate (Enable):
http://127.0.0.1:8080/json-1/list%7B"121"%7B"new_value":"1"%7D%7D
To Deactivate (Disable):
http://127.0.0.1:8080/json-1/list%7B"121"%7B"new_value":"0"%7D%7D
PostPosted: Thu Mar 05, 2026 1:40 am
Thanks for the reply, but where can I find the list of parameters to modify via JSON?
What a way to complicate things.
((( RadioFM )))
PostPosted: Thu Mar 05, 2026 2:42 am
The easiest would be to use the Web UI and "Inspect" the toggle or slider to see the Widget ID number. This number corresponds to the number in the JSON interface for the command you want to use.
PostPosted: Mon Mar 09, 2026 7:10 am
Thanks you MrKlorox for the info.
Best regards.-
((( RadioFM )))
