| Site Admin |
Hi all,
Latest version - Beta 10.71-024 (October 3 2025)
KNOWN ISSUE: macOS version does not have a valid code signature and might not work if you don't have internet access. Our old signing certificate expired and the new one doesn't work. No Mac versions will be released until this issue is solved.
Downloads
Windows:
Pi (ARM Linux) 64 bit:
Pi (ARM Linux) 32 bit: (STILL BUILDING)
macOS:
Changes/bugfixes
- libStereoTool: stereoTool_Create3 can now also overrule target .ini/.rc path, and whether to load it on start
- libRIST add watchdog with restarts - https://support.thimeo.com/scp/tickets.php?id=12174 - RIST on the decoder side now reconnects after 90 seconds with no packets, and will then keep retrying with increasing time intervals.
- RIST timing for GPS sync needs to be clarified; times need to be added. See email exchange with Ross, Fri Sept 19 2025, 12:27 -> Solved by adding (visibly as well!) RIST delay to main delay, and actually *applying* it to the GPS delay if that's used.
- Added streaming metadata to logging console. Open the console window if you have issues with artist/title/song info on streams. (Adding to the display will be much easier after the I/O redesign that Tom is working on)
- MicroMPX encoder and decoder didn't show if SFN and MicroMPX+ were registered. Now they do.
- Verify that streaming works on STXtreme
- Software updates are broken on Pi image, maybe also on STXtreme? Test all 3 (Pi, STXtreme, STB)
- STudio and PiMP could sometimes attempt to use the wrong low latency sound card, causing errors. Now hard coded to use HifiBerry; if you want to use any other card you'll need to change a script slightly.
- Bojcha's glitch error issue - APPEARS TO BE SOLVED..... Doesn't reproduce in 10.71 BETA021, did happen in 10.70.
- Fixed most automatic tests
- Fix MicroMPX verify popup after updating on SD card image
- Fix automatic tests to reply to updater popup
- GUI: All widgets in overview screen now have the same width
- GUI: Menu's without a page behind it don't look highlighted anymore on mouse over.
- GUI: BS412 box is zoomable, till 24 hours
- GUI: Clicking on scope doesn't navigate to I/O anymore.
- GUI: ^F didn't work to open preset
- Fake Stereo: Added more precision to setting, and shrunk scale to a more reasonable range
- Absolute Highs: With certain combinations of settings could cause crashes. But has been there forever, apparently nobody ever noticed it.
- ProcessingChain: HD de-emphasis object could be used by multiple threads at the same time. Could cause audio artifacts - has never never been reported.
- RDS PS nullptr issue when line starts with /
- Increased internal buffer that could trigger "audio glitch" warning popups on overruns and software stalls, for 64 bit builds (uses a bit more memory)
TOP PRIO TODO's
- Added Multicast TTL setting for MicroMPX
- D add some level offset for output gain for analog outputs
- Duplicate L/R audio to LQLL
- TV
- S: Windows-64bits, Linux X86_64 and ARM64/CortexA53, and optionally later, if available, Windows-32, darwin-arm64, LinuxARM32/CortexA9
- Glitch occurred - monroe2
- Streaming hangs if now playing info is read from a remote drive that hangs - causes timeout followed by login errors. 1. Put reading in a different thread. 2. Why login errors?
- Q: Add UECP port binding
PRIO TODO's
- Make it possible to set IP address via web interface on Pi image
- List of customers (name, country, licensed features, price, date, invoice #)
- Fix MicroMPX-like updater links for all products
- SFN graph (block diagram). Leo Bodnar feeds Nautel transmitter, ST 2x, explain that it locks amplitude, frequency and audio timing.
- Update Pi SD card images
- Run MicroMPX as a service in Windows
- Snooze MicroMPX encoder level warnings, currently complains if above 100.1% or if below 99.9% and keeps nagging. Or some other solution to make it less "loud".
- SD+IP I/O via ffmpeg
- BS412 slow leveler
- Quick Adjust: Maybe add single slider for band linking
- Maybe support AI translations - but how? (external developer) BUSY
- Create single persistent Python version of SNMP monitoring tool for Pi SD card image BUSY
- MicroMPX monitoring tool
- R128 live - look up specs
- Test SDI
- WatchCat: Add ffmpeg to installer, and remove need for scripting for that. Also make that a free option.
- MicroMPX: Add simple UDP packet forwarder. (what about RIST?)
- MicroMPX: Allow telling MicroMPX which ports to combine for the same stream (v5? maybe unique stream id in rtp?)
- MicroMPX V5
- Add EDI support! Remarks Peter van Ak... AAC block size 960 (FDK code patch), EDI headers, later EDI metadata via input.
- ShoutCast V2
- Disable chkdsk in boot, see my reply email from 3/Apr/2025 14:43. See also https://chatgpt.com/c/6800ad26-a3c0-800 ... a34fea7465 to prevent this from happening.
- NEW FM CLIPPING IDEA: Pre-analyse highs loss and compensate for it, to allow more snappy highs though on FM
- Top-of-hour ID in MicroMPX and ST
- EAS in MicroMPX and ST, ask Josh
- HLS, via ffmpeg, also on Pi/Mac
- JSON interface documentation, plus documentation of UECP mode, and best practices for creating a new preset, and simple explanation about how to modify existing presets.
- Auto Pilot
- Preset descriptions. Separate categories. Filtering for specific formats, maybe with checkboxes per preset to set those.
- Low bitrate AAC processing (Norway etc)
PRIO BUGS:
- Mac signing
- VLC input can loop old audio: https://forums.stereotool.com/viewtopic ... 864#p78864
- Keyboard input issue in 10.70: https://forums.stereotool.com/viewtopic.php?t=35234).
- Check: Bug report that channel linking is broken in 10.70: https://forums.stereotool.com/viewtopic.php?t=35227
TODO's (build system)
- Mac signing
- Bojcha: Something is wrong with final limiter mode (part of final clipper). See Discord August 26 2025
- Check email delivery issue
- VST3 MSI installer for Windows with silent mode - https://www.youtube.com/watch?v=kn4aPKgHHIM
- Renamed .so files must be patched with patchelf --set-soname libStereoTool_noX11_arm64.so libStereoTool_noX11_arm64.so
- Suppress "A piece of audio was missing" message from constantly popping up.
- Show red error text (PSTATICTEXT with SetError(true)) above Input 1 + 2 settings when backup is running. See SetBackup call.
- MicroMPX: Decoder hangs when sending multiple RIST streams to the same port number, and then stopping the one it's listening to.
- MicroMPX: Add very simple file player with pilot/RDS. Page with backup player settings (MP3/WAV) + RDS settings. 1 extra tab in web interface. Maybe add uploading, support very low speeds. Play from USB (D).
- MicroMPX: Make both output channels separately adjustable
- MicroMPX: Add option to add phase inversion
- Mathijs: Check Stokkemask stereo effect, can we reduce that? BUSY
- Attempt to remove mallocs in webserver code: ServerWorker::tryWebsocketHandshake, excludeWarnings
- Attempt to reduce mallocs in preset saving code
- Web server: Close connection if it is not used for a long time, or increase max connections. Someone has connection issues with too many windows open: https://support.thimeo.com/scp/tickets.php?id=11202
- include/shout/shout.h need to be generated from shout.h.in somehow (can be a sed command if needed)
- Check lib-untracked origins
- Where do we put the build scripts (pscp, tar, plink)
- AES67: Hiccups for someone using HD out with Dante, waiting for feedback. Finish smoothing code and hope for the best...
- 10.51: ABE version does not have ABE colors or login accounts - Wait for feedback, override default colors (and maybe saving them)
- Clara HW test
- Optimization: Exchange latency for quality for STB
TODO's (not related to build system)
Tom:
- Multiband load preset can make number of visible bands go up/down constantly
- Full screen mode is saved to presets! Should not.
- iPhone 15 misses labels in Chrome
- DcWave add delay, maybe make it work same as Wave, because now it's displayed unsynchronized with everything else.
- Usability: Maybe redesign how RDS now playing text inclusion works?
- Usability; Show streaming data in GUI (artist, title, song)
- Multi-instance: Tray icon should not show instance 0, and ! if there's any error
- Multi-instance: ! in overview if something is wrong
- Tab navigation should show abbreviated texts
- Don't center titles in narrow mode
- ST-Enterprise: Copy presets to other instances
- Compile ST to webassembly?
- More different meter colors.
- SCStreamingOutput is now a combination of VLC and builtin streaming, messy.
- Split presets into built-in and user
- LADSPA (or LV2) plugin? For ffmpeg, among others. Or inside ALSA(?).
- Load presets via JSON API
- Arrow in tiny info, maybe add sample rate? Maybe add optional element if there is space to bandpass display.
- Maybe add option to select what to see in meter bar
- MacOS: GUI doesn't move unless the window size is changed (VST2, VST3, stand alone not tested)
Hans:
- STXtreme extra instance 8-character code registration doesn't know the file name where to store the license key.
- Check if UECP RT A/B flags are handled correctly. Mail Matt Paton 18 jun 8:50AM
- MicroMPX: Jeroen: op jullie pi image kun je de NIC niet kiezen, alleen default of loop
- Mathijs' feature for new preset! Needed for YourSafe. Auto EQ after AGC would be nice to test
- Export EXPORT.GUI list including parameter enum names, and include in libStereoTool zip file.
- MicroMPX: Show warning if MicroMPX is enabled in ARM build at 44.1 kHz (doesn't work).
- MicroMPX: Add PWARNINGs for errors that need a popup, for example entering wrong license key
- Build: Test: Stereo Tool Pi CPU usage
- Build: Add LInux (intel/ARM) VST3 builds
- Investigate glitches when using Generic plugin in high CPU mode (could be on the caller's end)
- New compressor: Add pre-compression clipper to reduce effect of loud highs that will be masked by clipping/limiting
- Check if median levels are correct, may be displayed at wrong level
- SCInstance 848 mutex can hang (Mac, with insane CPU load)
Overall:
- URGENT: Socket error in libShout, followed by not reconnecting.
- Bug: When a LiveWire channel is selected in the pulldown, but nothing is detected anymore, after restarts it overwrites the channel that's selected in the fill-in field next to it.
- NEW COMPRESSOR IDEA: Maybe set a minimal speed, easier to use than speedup on drops. Nice curve into it. -> Probably not needed, issue was caused by Casper and that's fixed now.
- Is some Auto EQ-like behavior in the new compressors useful to prevent too much sound adjustment? Or should we just make the bands wider? -> "Soft linking" fixed this. Maybe something is needed for R128?
- Photos to travel site, and update it
- Allow Auto EQ after AGC (or better: Let it output a sidechain with only weakening of levels) (Mathijs)
- MultiVOC Jack version more than 2 channels
- MicroMPX: On our SD card image, it doesn't show the NIC for ETH0 in the pulldown menu - why??? Works fine in other images.
- Check if input affinities are set
- AES67 Do we want to also support the system clock, including any offsets that are applied to it? Probably not?
- File player for top-of-hour legal ID (for both MicroMPX and ST)
- UMPX TESTS F
- MicroMPX v5: RTP
- MicroMPX v5: RIST
- MicroMPX v5: Improve quadrature encoding for very clean signals to avoid rounding errors in peak level detection.
- MicroMPX v5: Add GPS timestamp to encoder library API so others can use our encoding
- MicroMPX v5: Email joost 2
- MicroMPX V5: Add partial keyframes for faster recovery without resending everything
- MicroMPX v5: Re-check if 38.4 kHz is the ideal sample rate, since we never want audio above 16.4 kHz anyway!!!!!!!!!!!!!!. Can we use a frequency such that no LPF is needed (eg 33 kHz)?
- MicroMPX v5: Check GPS calculation error (inverted atan, //TODO in GpsSyncedSoundcardOutput line 494)
- MicroMPX v5: Maybe encode highest audio frequency
- MicroMPX: Better way to tell it which ports contain the same signal (currently must use same port number)
- Streaming input on Pi.
- Directly after new build system: Put PhoneBooster in VST plugins
- Directly after new build system: Add VST Linux support
- Directly after new build system: Add AU support
- Check reported "Socket error" in output stream. Apparently new in 10.50 but I don't know if that's true. https://support.thimeo.com/scp/tickets.php?id=9990
- Streaming blocks if now playing file drive is unreachable (10.21): https://forums.stereotool.com/viewtopic.php?t=33962
- Linux: "Full screen" mode - after closing the software opens without a GUI. Workaround added, real fix needed later.
- Potential AAC streaming issue on Pi: https://forums.stereotool.com/viewtopic.php?p=77926
- Create C++ version of SNMP monitoring tool for Pi SD card image
- K Black Pi RDS2 issue - fine on Windows, potentially ARM code error
- Bug: HD output level is reduced when using BS412. Has been this way forever...
- Add libVLC support to Linux/Mac builds (for OS parity)
- Pi image: Check Pi memory patch
- Check VST3 crash on Mac TOM
- Check VST in Auditon on Mac TOM
- MicroMPX multicast issue directly after startup
- MicroMPX: Export the control signal that would control when the backup player becomes active to the JSON and library outputs so GPO's can be coupled to it.
- Web interface KoekError display: Add last error time to web interface. But NOT for MicroMPX, because there the time is already part of the error message - or change that, but identical messages must still be logged separately in that case.
- Output streaming via libVLC is broken; it does not detect when there's no connection, and does not detect connection loss in VLCGetBuffers. So it does not properly reconnect after an error.
- Check Hard Limit behavior (Bojcha)
- Add + button for streams, to make page less crowded
- MicroMPX: When signal comes back, backup player stops and silence is played, can be 14 seconds if that's the buffer size.
- Vorbis: Add sample rate; if we're running at 192 kHz that's also the stream sample rate, should be 48 in that case.
- MicroMPX Add way to set IP address - but how??
- Re-enable MPX demodulator settings in Stereo Tool (MPX Tool-like)
- STXtreme 5 FM instances doesn't work if more than 2 are set to latency 128. Do more measurements and figure out what the limits are.
- STXtreme: Implement smart glitch detection INTERNALLY so we don't need to run external tests all the time. Maybe we can already see it!
- STXtreme multi-instance hiccups system Matt - why?
- STXtreme: Audio seems fine even though buffer display shows that the buffer is very low.
- MicroMPX: Add/modify JSON parameter that shows total used bitrate to include RIST, plus number of RIST clients.
- MicroMPX: Add way to set IP address of hardware
- Multple streams: Support different metadata??
- MicroMPX decoder: RIST: Figure out way to get rid of RIST delay, or how to sync with non-RIST and how to specify RIST vs non-RIST delays - LATER
- MicroMPX decoder: RIST: How to handle RIST delay in combination with GPS
- Would it be possible to make an R128 measurement there, where I can set the measurement period for a sliding window between 1 and about 5 minutes?
- MicroMPX: Reduce RIST overhead
- Clipper + Hard Limit makes the spectrum dirty, mainly for pure sine waves - but why?
- MicroMPX library: umpxDecoderDecryptAnalysePacket may try to decode a packet while internally a packet is already being decoded, causing threading issues.
- MillingBroadcast's MicroMPX speed issue with encoder in Stereo Tool on Linux: https://forums.stereotool.com/viewtopic ... 454#p77454 - Waiting for feedback
- Silence detector in ST with email/SMS?
- Bojcha (via Discord personal chat with images): Clipper (measured HD out, no pre-emphasis) has HOLE between 5kHz and 13kHz about 0.4dB. Only way to fix it is to set Highs clipping from +1.51dB (default) to +0.95dB. He says it sounds better too... (less gaps due to highs, not less highs)
- MicroMPX: Add GPS support for decoder without NMEA. That's how others do it - they just use the timestamp in the packet as the time of the closest 1PPS pulse. Will simplify the hardware!
- MicroMPX: Silence detection in MPX is used to switch between studios! So reporting levels is really necessary.
- Mathijs: Als je de AGC in Matrix mode gebruikt (trouwens voor MB hetzelfde denk ik), dan wil je eigenlijk channel linking gebruiken om te voorkomen dat L-R heel extreem bijgetrokken wordt tov L+R. Alleen: als dan de hoeveelheid stereo content flink toeneemt kan het zijn dat L-R de L+R mee omlaag trekt, en dat wil ik eigenlijk niet. Dat gebeurt sneller als je ook nog die "Stereo boost when AGC is below threshold" setting gebruikt. Zou fijn zijn als die channel link maar één kant op kan werken; dus dat L+R altijd vrij kan bewegen en dat L-R daar aan vast gelinkt hangt
- Vinyl bass rumble removal
- 32 bit CortexA53 old GCC version for GA
- Can we use USE_COMPACTED_STORAGE by default? Would save a lot of memory.
- MicroMPX doesn't show EF mode error in Stereo Tool plugin version.
- < 150 Hz mono to remove rumbly on vinyl.
- Insert points: Via the sound card to outside and back? Or via VST's. To enable adding effects.
- Vinyl click detection and removal.
- Report that VST3 on Mac crashes on startup
- Sound cards: Add VLC to input 2 for backup - but that requires a fix for when the stream drops out.
- Website: Write description of how to set up ST + MicroMPX, seems to be difficult for some people to find.
- Add loading presets via JSON (nrk)
- Finish US pricing, update prices.
- MicroMPX overview app
- When sound card/stream recovers after error, clarify current message which appears to indicate that it's not streaming at all.
- Remove Stokkemask Clipper?
- Remove Simple Clipper from STXtreme
- Phase Delay isn't disabled at low latency settings, causing extra delay.
- MicroMPX GPS: Extreme amounts of logging when GPS data doesn't come in due to bad antenna. Causes disk to fill up in a day, so the logging cleanup also doesn't help.
- LiveWire 48 kHz FM output doesn't work with ASIO
- Streaming: Add FLAC support
- Test SDI
- GUI: Sound card buffer slider behavior
- Verify that inputs 1 and 2 have separate tilt corrections.
- Analyzer
- Mac AU plugin should be easy to make now
- Create small program to send UDP or TCP commands for UECP. Maybe even real UECP commands... Could be the start of a new product
For now, ncat works (example: echo PS=Hello | ncat 127.0.0.1 4001), see https://nmap.org/download.html#windows
- I/O: Add file input (and output?) so we can use files as backup material. Maybe both let it run all the time or make something like in MicroMPX that only plays when needed and pauses in between.
- I/O: AES67
- MicroMPX: Make readSlidingWindow smarter; only copy if necessary (lazy).
- MicroMPX V5: Add L/R peak levels to encoder and decoder libraries.
- MicroMPX V5: Simplify header structure
- Add test tones to check phase and level issues for FM, like in old calibration.
- Fix stepping of sound card buffer sizes (without control/shift should be 1, not .1 or 10).
- Add RDS2 slide shows
- Check report: Generic plugin crashes on mono input
- GUI: Don't show 2nd channel for mono processing
- Delay issue in MPX display; not synchronized with the audio.
- Overview screen password protection: How should that work?
- Overview screen: Error should be shown here.
- Mono bass for HD cannot be enabled without enabling the other "Reduce stereo" settings as well; needs to be split off just like for FM.
- MicroMPX: Somehow detect and report number of incoming streams
- Do something to draw graphs even without audio
- Pragma messages: Check and remove where possible
- Check BIMP meter bar; dynamics section MB on/off removes top bar
- MicroMPX: Add error checking for IP addresses, don't open if the address isn't complete. (Maybe wait for ENTER? - Web interface).
- Improve sound card error messages on STXtreme
- MicroMPX: “umpxDecoderGetStreamFeedback()”: the signal lost counter in umpxDecoderStreamInfo seems to be stuck or sometimes not to count up when there is no input (with pilot generation active, internal sync turned off). I can’t rule out the problem is on our side, but it was working before and I think we did not change anything handling the umpxDecoderStreamInfo.
- Streaming must read data from files from a separate thread, https://forums.stereotool.com/viewtopic.php?p=75718
- Can we add an automatic gate for Blue Monday? Detecteer harde tikken die even hard zijn als input maar toch steeds harder worden en te hard zijn.
- STAMP license error message is only visible in the native GUI (which doesn't exist); how do we show it in the correct GUI (the one in which the button was clicked)? Same question for overview page.
- DHD: Remove logging, probably.
- DHD: Add FM Professional to purchase options on the site.
- Fix Declipper issues reported in https://forums.stereotool.com/viewtopic ... 4&start=30 and on Discord
- Restart when sound card does not work is not working anymore
- .st.gui_override does not survive firmware updates in SD card image; needs to look in root directory.
- AES67: If a LiveWire port is selected under "Device" but nothing is detected there, that port number overwrites the active port field on preset loading. The pulldown itself cannot be changed if nothing is detected.
- Advanced Clipper: MAYBE make a filter that limits how much bass mids and highs protection can remove at the most. Can be done later.
- AGC: Most likely we'll also need to change the release behavior compared to the compressors.
- AGC: Bojcha: Some other stuf really needed, - startup level - return to platform - gate after agc (please) - some sort of compressor or some protection for bursts like on old AGC - why freeze is not fully freeze (there is delay)
- MicroMPX: Run as service?
- Loading a Stereo Tool preset on PiMP also sets things like whitelist, blocking access.
- Make RDS/RDBS selectable or something, independent of 50/75 us pre-emhpasis.
- New compressor: Matrix mode: Limiters work on L+R and L-R, instead of L and R. That's probably bad.
- MicroMPX: Allow RDS settings in library?
- PEQ in MicroMPX FM output?
- Sensitivity scrolling vs sliding
- MicroMPX: Check pilot cleanness in decoder if pilot frequency is slightly off (19005 Hz).
- Also, I notice when adjusting the buffer, there's no way to adjust by 1ms. There's 0.1ms (CTRL), 10ms (SHIFT), but it doesn't go by 1ms when no modifier is held. It would also be very handy to have the Synchronize with HD slider in between the HD and FM output cells instead of hidden in the More FM Output Settings.
- Reset skin, and other things (basically anything that can be loaded?)
- Pi: Make network settings changeable via web interface.
- Startup delay on MicroMPX?
- Update LiquidSoap links
- mndxer1049: Better Natural Dynamics section with WB dynamic detection
- mndxer1049: A very transparent, C-Level like new AGC design
- mndxer1049: Auto Stereo Pilot
- mndxer1049: Maybe: A button for putting all CPU settings at the maximum value and turning on all CPU intensive settings that only improve audio, but take quite a bit of CPU load. (ex. sliders like ‘Quality (increases CPU load)’ under DeClipper restoration, “Strictness (CPU)” and “Leif’s highs gap protection stages (CPU)’ under Clipper just to name a few of these ”CPU sliders” I’m referencing.)
- Display bug in MPX display (weird spectrum glitches that occur occasionally)
- Add streaming output to VST version?
- In the audio input section I'd like to see options for speakers to be included without having the need to use virtual cables to route. I was thinking something similar to Rocket Broadcaster. There's input for mic and separate application source.
- MicroMPX decoder: High frequency tilt correction is performed BEFORE data is collected for display, looks like overshoots.
- Auto pilot
- Redesign ND dynamics detection
- Maybe add some frequency display to MPX display. https://forums.stereotool.com/viewtopic ... 16&t=33720
- Add numeric displays to ITU and MPX levels in GUI https://forums.stereotool.com/viewtopic ... 16&t=33686
- Insert/delete bands in multiband compressor, instead of (like now) just having to add/remove the last one when the number of bands changes.
- Non-phase linear: For example https://github.com/nxsEdson/Butterworth ... rworth.cpp
- STXtreme errors when reusing sound card
- STXtreme set shared sample rate (instances can set different sample rates)
- Azimuth affects highs!!
- Ratio slider smarter steps (1.1, 1.2 etc) - MattL
- Meters: add separate FM/HD output level displays.
- New compressor and matrix mode?
- Add 0.05 precision to parametric EQ and attack/release multipliers
- RDS: Add settings for how long texts are shown or how fast to scroll for UECP inputs.
- AES67 generic mode: Let people enter IP address directly.
- MicroMPX: Show temperature
- MicroMPX: Show status per incoming port
- Links: ID_GOTO must be a PLink that points somewhere.
- Dynamic speeds: License detection only works after audio has been running, that's not ok.
- When audio has run after a settings change, trigger a parsetChanged
- Time offset on STXtreme, for RDS (also for ClockTime!)
- New GUI: Support smaller monitors (smaller default size, especially for VST). Contact near05.
- Export presets from web interface needs filtering, just like from native (so the code is there! Just reuse CopyPresetOm*).
- Mac: VST2 sizes
- Mac: gavinmcgrath: "Intel MacOS 11.7.3 in Wavelab 11.1: Blank screen." https://forums.stereotool.com/viewtopic ... 407#p73407
- Stand alone RDS decoder
- CPU usage of REFRESH_ENABLED is high, maybe use local array.
- PDcWave delay not set
- WatchCat: Keep track of when files have been processed and ignore them, but don't move them. (DropBox)
- WatchCat: Can we include ffmpeg and lame?
- Add latency wizard?
- setFaultyValue for text boxes for wrong passwords for example - check with Tom how to use
- Can we enable FM Calibration in "Ignore high frequencies" mode? Not easily
- Add check for running ST multiple times; make switchable if we want to allow it or ask if you really want to start if it already runs or something.
- Matt: Pre-emphasize highs slider needs to get a clearer description! Something with avoid overshoots. Basically a sidechain EQ. "Add highs to sidechain".
- Matt: UECP must be more easily accessible, too deep now.
- Matt: FM+AM
- New I/O framework: Add extra latency to plugin input so the input 2 to LQLL can be instantaneous.
- Check Bojcha's good bass HPF settings (18200 Hz, ignore high frequencies, 48 kHz, 35 Hz HPF)
Latest version - Beta 10.71-018 (September 24 2025)
Downloads
Windows:
macOS:
Changes/bugfixes
- 7.1.4 audio (12 channels) support in all 64 bit plugins. This does increase memory usage, so we've limited it to 64 bit builds only. Please let us know if this causes issues.
- D tilt in hidden pw mode, June 25 - verification needed
- Added option to override .rc file name for libStereoTool (stereoTool_Create3)
- Error/warning pulldown was not scrollableTom
- Clicking a dropped dropdown wouldn't close it Tom
- Some label texts weren't filled when shown the first time Tom
- Check all NOLOADSTX's etc, add NOLOADSAVESTB's
- libStereoTool: Added stereoTool_Create3 that can overrule target .ini/.rc file name
- Current preset text is now fully shown, unless there is not enough space Tom
- Sound card errors displayed in buffer bars no longer rearrange settings blocks Tom
- Button pressing code rewritten Tom
- Added JSON command to load presets
- Updated Pi SD card image, made most manual setup steps automatic
- Enterprise overview screen now allows you to see and load presets
- Improved a lot of translation behavior
- StereoToolBox drawing code could crash if there was a too small screen attached, size check was missing.
Latest version - Beta 10.71-015 (September 11 2025)
KNOWN ISSUE: Mac version does not have a valid code signature and might not work if you don't have internet access. Our old certificate expired and the new one we got doesn't work, apparently (according to ChatGPT, so take this with a whole spoon of salt) due to some issue on Apple's servers. No Mac version will be released at this point.
Downloads
Windows:
macOS:
Changes/bugfixes
- STXtreme: Network settings page on front panel could be unreachable if a static IP was configured in 10.70. Reason unknown, but it no longer happens.
- Made lots of improvements on the SD card image (not yet posted), among others it can now use port 80 instead of 8080 for the web server, and future updates can do a lot more (will require a new image to be put on the SD card).
- Several small unrelated fixes of things that broke in earlier beta's in this series.
Latest version - Beta 10.71-011 (September 5 2025)
Downloads
Windows:
macOS:
Changes/bugfixes
- Ignore hw:0.0 in ALSA device names if no exact match. A mismatch (which is really rare) could cause a sound card was not found error on Linux, for example on our Pi image).
- MicroMPX: "Soft linking" in 1 direction - soft linking had too much effect on bass. You can now enable it only for the highs.
- D/STB: Create version of startup program for ONLY MicroMPX/STB.
- D/STB: Enable web updates via webinterface, for only 1 product. Change calculation of checksum?
- Make it possible to set IP address via web interface on Linux with controlled OS image (D/STB)
- Bug fix: An audio device could be claimed before it was released, causing it to be never released anymore. This could potentially cause failed restarts and failed switching between sound cards.
Latest version - Beta 10.71-004 (August 20 2025)
Downloads
Windows:
Pi (ARM Linux) 32 bit: (BUILDS FAILED)
macOS:
Changes/bugfixes
- Fixed issue where files with weird characters could not be opened. This affected presets, and also .ini files for users with Windows user names with weird characters in them.
- Fixed JSON error list (all error strings were empty in the last few MicroMPX releases).
- Renamed Thimeo ST-Enterprise to Thimeo Enterprise
Latest version - Beta 10.71-002 (August 16 2025)
Downloads
Windows:
macOS:
Changes/bugfixes
- Fixed crash on closing in BETA001 (at least in 32 bit DSP on Windows), caused by mismatch in build flags for one library.
- Added "type" field to JSON responses.
Latest version - Beta 10.71-001 (August 15 2025)
Downloads
Windows:
Changes/bugfixes
- Windows build: Optimizations for older Intel CPU's don't appear to have worked properly. Performance might be better now. Binaries are also bigger.
- MicroMPX: Added GPS using internal clock instead of NMEA (still with external 1PPS signals) mode to Linux builds (experimental).
- Big code cleanup: External libraries updated. OpenSSL replaced by LibreSSL (may affect streaming to HTTPS servers).
- Report that there's no output selection in libStereoTool, so you always get pre-emphasized out: https://support.thimeo.com/scp/tickets. ... 1681#reply
