Post new topic  Reply to topic  [ 55 posts ]  Go to page 1 2 3 4 5 6 Next
PostPosted: Sun Mar 16, 2025 10:04 am
Hi all,
Latest version - Beta 10.53-048 (July 15 2025): RELEASE CANDIDATE + EXTRA'S
KNOWN ISSUE: Mac version does not have a valid code signature and might not work if you don't have internet access. Our old certificate expired and the new one we got doesn't work, apparently (according to ChatGPT, so take this with a whole spoon of salt) due to some issue on Apple's servers. No Mac version will be released at this point.
Downloads
Windows: Pi (ARM Linux) 64 bit: Pi (ARM Linux) 32 bit: macOS: Changes/bugfixes
  • Multiband soft band linking (initial proof of concept version), NOT IN UPCOMING RELEASE. Results in a much less "in-your-face" sound without sacrifycing much consistency. See Bands - Band interactions - Band linking, enable "Soft" mode. dB-values are no longer perfectly observed (you'll likely need to increase them), suggested settings is 9 dB for the 4 top bands.
  • GUI: Reorganized streaming page
TODO's (build system)
  • Mac signing
  • MicroMPX: Add simple UDP packet forwarder. (what about RIST?)
  • MicroMPX: Add very simple file player with pilot/RDS. Page with backup player settings (MP3/WAV) + RDS settings. 1 extra tab in web interface. Maybe add uploading, support very low speeds. Play from USB (D).
  • MicroMPX: Make both output channels separately adjustable
  • MicroMPX: Add option to add phase inversion
  • Mathijs: Check Stokkemask stereo effect, can we reduce that? BUSY
  • Check MB band linking in % BUSY
  • Attempt to remove mallocs in webserver code: ServerWorker::tryWebsocketHandshake, excludeWarnings
  • Attempt to reduce mallocs in preset saving code
  • Web server: Close connection if it is not used for a long time, or increase max connections. Someone has connection issues with too many windows open: https://support.thimeo.com/scp/tickets.php?id=11202
  • include/shout/shout.h need to be generated from shout.h.in somehow (can be a sed command if needed)
  • Check lib-untracked origins
  • Where do we put the build scripts (pscp, tar, plink)
  • AES67: Hiccups for someone using HD out with Dante, waiting for feedback. Finish smoothing code and hope for the best...
  • 10.51: ABE version does not have ABE colors or login accounts - Wait for feedback, override default colors (and maybe saving them)
  • Clara HW test
  • Add EDI support! Remarks Peter van Ak... AAC block size 960 (FDK code patch), EDI headers, later EDI metadata via input.
  • ShoutCast V2
  • Optimization: Exchange latency for quality for STB
TODO's (not related to build system)
Tom:
  • Multiband load preset can make number of visible bands go up/down constantly
  • Full screen mode is saved to presets! Should not.
  • iPhone 15 misses labels in Chrome
  • DcWave add delay, maybe make it work same as Wave, because now it's displayed unsynchronized with everything else.
  • Usability: Maybe redesign how RDS now playing text inclusion works?
  • Usability; Show streaming data in GUI (artist, title, song)
  • Multi-instance: Tray icon should not show instance 0, and ! if there's any error
  • Multi-instance: ! in overview if something is wrong
  • Tab navigation should show abbreviated texts
  • Don't center titles in narrow mode
  • ST-Enterprise: Copy presets to other instances
  • Compile ST to webassembly?
  • More different meter colors.
  • SCStreamingOutput is now a combination of VLC and builtin streaming, messy.
  • Split presets into built-in and user
  • LADSPA (or LV2) plugin? For ffmpeg, among others. Or inside ALSA(?).
  • Load presets via JSON API
  • Arrow in tiny info, maybe add sample rate? Maybe add optional element if there is space to bandpass display.
  • Maybe add option to select what to see in meter bar
  • MacOS: GUI doesn't move unless the window size is changed (VST2, VST3, stand alone not tested)
Hans:
  • STXtreme extra instance 8-character code registration doesn't know the file name where to store the license key.
  • Check if UECP RT A/B flags are handled correctly. Mail Matt Paton 18 jun 8:50AM
  • MicroMPX: Jeroen: op jullie pi image kun je de NIC niet kiezen, alleen default of loop
  • Mathijs' feature for new preset! Needed for YourSafe. Auto EQ after AGC would be nice to test
  • Export EXPORT.GUI list including parameter enum names, and include in libStereoTool zip file.
  • MicroMPX: Show warning if MicroMPX is enabled in ARM build at 44.1 kHz (doesn't work).
  • MicroMPX: Allow telling MicroMPX which ports to combine for the same stream
  • MicroMPX: Add PWARNINGs for errors that need a popup, for example entering wrong license key
  • Build: Test: Stereo Tool Pi CPU usage
  • Build: Add LInux (intel/ARM) VST3 builds
  • Investigate glitches when using Generic plugin in high CPU mode (could be on the caller's end)
  • New compressor: Add pre-compression clipper to reduce effect of loud highs that will be masked by clipping/limiting
  • Check if median levels are correct, may be displayed at wrong level
  • SCInstance 848 mutex can hang (Mac, with insane CPU load)
Overall:
  • URGENT: Socket error in libShout, followed by not reconnecting.
  • Disable chkdsk in boot, see my reply email from 3/Apr/2025 14:43. See also https://chatgpt.com/c/6800ad26-a3c0-800 ... a34fea7465 to prevent this from happening.
  • NEW FM CLIPPING IDEA: Pre-analyse highs loss and compensate for it, to allow more snappy highs though on FM
  • NEW COMPRESSOR IDEA: Maybe set a minimal speed, easier to use than speedup on drops. Nice curve into it.
  • Is some Auto EQ-like behavior in the new compressors useful to prevent too much sound adjustment? Or should we just make the bands wider?
  • Photos to travel site, and update it
  • Allow Auto EQ after AGC (or better: Let it output a sidechain with only weakening of levels) (Mathijs)
  • Sudden Drop Protection can be triggered to be always active, unknown why. Maybe something goes to NAN internally? (Mathijs)
  • MultiVOC Jack version more than 2 channels
  • MicroMPX: On our SD card image, it doesn't show the NIC for ETH0 in the pulldown menu - why??? Works fine in other images.
  • Check if input affinities are set
  • AES67 Do we want to also support the system clock, including any offsets that are applied to it? Probably not?
  • TEST popup multicast network
  • File player for top-of-hour legal ID (for both MicroMPX and ST)
  • UMPX TESTS F
  • MicroMPX v5: RTP
  • MicroMPX v5: RIST
  • MicroMPX v5: Improve quadrature encoding for very clean signals to avoid rounding errors in peak level detection.
  • MicroMPX v5: Add GPS timestamp to encoder library API so others can use our encoding
  • MicroMPX v5: Email joost 2
  • MicroMPX V5: Add partial keyframes for faster recovery without resending everything
  • MicroMPX v5: Re-check if 38.4 kHz is the ideal sample rate, since we never want audio above 16.4 kHz anyway!!!!!!!!!!!!!!. Can we use a frequency such that no LPF is needed (eg 33 kHz)?
  • MicroMPX v5: Check GPS calculation error (inverted atan, //TODO in GpsSyncedSoundcardOutput line 494)
  • MicroMPX v5: Maybe encode highest audio frequency
  • MicroMPX: Better way to tell it which ports contain the same signal (currently must use same port number)
  • Streaming input on Pi.
  • Directly after new build system: Put PhoneBooster in VST plugins
  • Directly after new build system: Add VST Linux support
  • Directly after new build system: Add AU support
  • Check reported "Socket error" in output stream. Apparently new in 10.50 but I don't know if that's true. https://support.thimeo.com/scp/tickets.php?id=9990
  • Create automatic test: TEST create account and log in and out, for Stereo Tool and for Enterprise, also for instance 2. Also test JSON token.
  • Streaming blocks if now playing file drive is unreachable (10.21): https://forums.stereotool.com/viewtopic.php?t=33962
  • Linux: "Full screen" mode - after closing the software opens without a GUI. Workaround added, real fix needed later.
  • Potential AAC streaming issue on Pi: https://forums.stereotool.com/viewtopic.php?p=77926
  • MicroMPX monitoring tool
  • Create C++ version of SNMP monitoring tool for Pi SD card image
  • K Black Pi RDS2 issue - fine on Windows, potentially ARM code error
  • Bug: HD output level is reduced when using BS412. Has been this way forever...
  • Add libVLC support to Linux/Mac builds (for OS parity)
  • Pi image: Check Pi memory patch
  • Check VST3 crash on Mac TOM
  • Check VST in Auditon on Mac TOM
  • MicroMPX: Export the control signal that would control when the backup player becomes active to the JSON and library outputs so GPO's can be coupled to it.
  • Web interface KoekError display: Add last error time to web interface. But NOT for MicroMPX, because there the time is already part of the error message - or change that, but identical messages must still be logged separately in that case.
  • Output streaming via libVLC is broken; it does not detect when there's no connection, and does not detect connection loss in VLCGetBuffers. So it does not properly reconnect after an error.
  • JSON interface documentation
  • Check Hard Limit behavior (Bojcha)
  • Add + button for streams, to make page less crowded
  • Maybe support AI translations - but how?
  • MicroMPX: When signal comes back, backup player stops and silence is played, can be 14 seconds if that's the buffer size.
  • Vorbis: Add sample rate; if we're running at 192 kHz that's also the stream sample rate, should be 48 in that case.
  • MicroMPX Add way to set IP address - but how??
  • Re-enable MPX demodulator settings in Stereo Tool (MPX Tool-like)
  • STXtreme 5 FM instances doesn't work if more than 2 are set to latency 128. Do more measurements and figure out what the limits are.
  • STXtreme: Implement smart glitch detection INTERNALLY so we don't need to run external tests all the time. Maybe we can already see it!
  • STXtreme multi-instance hiccups system Matt - why?
  • STXtreme: Audio seems fine even though buffer display shows that the buffer is very low.
  • MicroMPX: Add/modify JSON parameter that shows total used bitrate to include RIST, plus number of RIST clients.
  • MicroMPX: Add way to set IP address of hardware
  • Multple streams: Support different metadata??
  • MicroMPX decoder: RIST: Figure out way to get rid of RIST delay, or how to sync with non-RIST and how to specify RIST vs non-RIST delays - LATER
  • MicroMPX decoder: RIST: How to handle RIST delay in combination with GPS
  • Would it be possible to make an R128 measurement there, where I can set the measurement period for a sliding window between 1 and about 5 minutes?
  • MicroMPX: Reduce RIST overhead
  • Clipper + Hard Limit makes the spectrum dirty, mainly for pure sine waves - but why?
  • STXtreme: Add loopback test for handling brief power drops. BUSY
  • MicroMPX library: umpxDecoderDecryptAnalysePacket may try to decode a packet while internally a packet is already being decoded, causing threading issues.
  • MillingBroadcast's MicroMPX speed issue with encoder in Stereo Tool on Linux: https://forums.stereotool.com/viewtopic ... 454#p77454 - Waiting for feedback
  • Silence detector in ST with email/SMS?
  • Bojcha (via Discord personal chat with images): Clipper (measured HD out, no pre-emphasis) has HOLE between 5kHz and 13kHz about 0.4dB. Only way to fix it is to set Highs clipping from +1.51dB (default) to +0.95dB. He says it sounds better too... (less gaps due to highs, not less highs)
  • MicroMPX: Add GPS support for decoder without NMEA. That's how others do it - they just use the timestamp in the packet as the time of the closest 1PPS pulse. Will simplify the hardware!
  • MicroMPX: Silence detection in MPX is used to switch between studios! So reporting levels is really necessary.
  • Mathijs: Als je de AGC in Matrix mode gebruikt (trouwens voor MB hetzelfde denk ik), dan wil je eigenlijk channel linking gebruiken om te voorkomen dat L-R heel extreem bijgetrokken wordt tov L+R. Alleen: als dan de hoeveelheid stereo content flink toeneemt kan het zijn dat L-R de L+R mee omlaag trekt, en dat wil ik eigenlijk niet. Dat gebeurt sneller als je ook nog die "Stereo boost when AGC is below threshold" setting gebruikt. Zou fijn zijn als die channel link maar één kant op kan werken; dus dat L+R altijd vrij kan bewegen en dat L-R daar aan vast gelinkt hangt
  • Vinyl bass rumble removal
  • Report that VST3 on Mac crashes on startup
  • Sound cards: Add VLC to input 2 for backup - but that requires a fix for when the stream drops out.
  • MicroMPX overview app
  • Remove Stokkemask Clipper?
  • Streaming: Add FLAC support
  • Test SDI
  • Analyzer
  • I/O: AES67
  • Add RDS2 slide shows
  • Streaming must read data from files from a separate thread, https://forums.stereotool.com/viewtopic.php?p=75718
  • Fix Declipper issues reported in https://forums.stereotool.com/viewtopic ... 4&start=30 and on Discord
  • MicroMPX: Run as service?
  • PEQ in MicroMPX FM output?
  • Startup delay on MicroMPX?
  • Update LiquidSoap links
  • Auto pilot
  • Maybe add some frequency display to MPX display. https://forums.stereotool.com/viewtopic ... 16&t=33720
  • Add numeric displays to ITU and MPX levels in GUI https://forums.stereotool.com/viewtopic ... 16&t=33686
  • Azimuth affects highs!!
  • MicroMPX: Show temperature
  • Mac: VST2 sizes
  • Mac: gavinmcgrath: "Intel MacOS 11.7.3 in Wavelab 11.1: Blank screen." https://forums.stereotool.com/viewtopic ... 407#p73407
  • Stand alone RDS decoder
  • PDcWave delay not set
  • Add latency wizard?
  • Matt: FM+AM
Latest version - Beta 10.53-046 (July 12 2025): RELEASE CANDIDATE
Downloads
  • EXPERIMENTAL and will be removed before release: Extra Stokkemask settings that allow more highs to get through (VFW filtering, improved Gaussian formula). Suggested VFW value: 0.1 - 0.15 ms. THIS CODE IS BRAND NEW AND HAS NOT BEEN VALIDATED WITH AN EXTERNAL STOKKEMASK ANALYZER - IT MIGHT BREAK COMPLIANCE.
  • Debug only: Added startup verification code if .ini file exists to verify that the built-in preset is valid
  • Fixed some default parameter values and default preset parameter values to be in valid range
  • Certain sliders ("Allow louder female vocals" in old AGC for example) were broken; fixed behavior.
  • Dehummer: After disabling "Continuous Learning", CPU usage stayed high because one calculation was continuously repeated.
Latest version - Beta 10.53-045 (July 11 2025)
Downloads
  • libMicroMPX has unnecessary dependencies to libasound and libpthread.
  • MicroMPX log cleanup code ignored files > 2 GB on Windows
  • AGC: Added relative matrix mode ratio
  • Console version didn't load old default values for parameters missing from .sts file
  • Fixed issue in Adaptive compressor matrix mode that could cause L+R to be pulled down too much by L-R (since a few beta's ago)
  • "Reduce stereo difference to" value wasn't stored.
  • Phat Bass enabled state was coupled to True Bass since a few betas ago
Latest version - Beta 10.53-040 (July 5 2025)
Downloads
  • Matt's preset update
  • Top bar in native GUI: Preset name widget cannot take up the full space anymore
  • Added logout on startup if there's a default password (only relevant for customer specific builds)
  • MicroMPX: D license verification
  • MicroMPX web interface now has icons, and can shrink better due to that
  • Fixed some MicroMPX issues in the past few beta builds
  • MicroMPX: D colors Purple
  • MicroMPX: D tilt
  • MicroMPX: Error popup is cleaned up a lot. Time stamps are displayed more clearly, and identical errors are properly grouped now (that didn't work for all errors before)
  • Some things in the GUI could allocate memory while running, solved. Only first use of large elements or changing window size may trigger allocates
  • Fixed program icon (title bar in Windows)
  • If warnings are suppressed (don't show again), also don't show them in "messages".
  • Adaptive Compressor: Fixed code to prevent L-R having too much effect on L+R at lower ratio settings.
  • Improved buffer reuse in GUI, might slightly reduce memory usage.
  • Some things in the GUI could shrink too much since a few beta's ago, reverted. Also, presets page is wide again (broke in BETA039).
  • Web interface: Fixed user account (login) bug in the last beta's. Sometimes you couldn't change settings even after being logged in etc.
  • Web interface meterbar overlapping fixed, which could happen on small displays (phones).
  • Web interface: Pulldowns were not blocked when you're logged in with view-only rights.
  • Web interface: MicroMPX top bar has icons now, and can be shrunk using only those if needed.
Latest version - Beta 10.53-037 (June 29 2025)
Downloads
  • Mac audio bug fix: Channel selection did not work
  • Streaming: Clarified that Cert file is shared between all instances
  • Streaming: Clarified that instances after the first only use built-in streaming
  • Streaming: Enabling AAC on any output triggers the AAC license popup
  • Report that Stereo Tool 10.51 hangs-on-close in RadioBOSS, 10.41 was ok. https://support.thimeo.com/scp/tickets.php?id=9990 -> Ok on our end with latest DSP BETA, waiting for feedback, assuming resolved for now.
  • When pressing "Turn off unlicensed features", turn off compressor/agc completely if in Adaptive mode. Show a big warning. -> Confirmation question
  • Added more Vorbis warnings (to console window)
  • Fixed snoozing of annoying popups that popped up continuously
  • STXtreme license extra instances field was not visible since 10.50.
  • Fixed AAC license popup
  • Make ECC and Language part of standard RDS instead of Advanced RDS, mandatory in some places.
  • CHECK: Gui-ID's * 2 + 1 etc shouldn't be needed anymore.
  • CHECK: Natural Dynamics display too wide in web interface
  • CHECK: Report: GPS icon does not turn green in MicroMPX decoder
  • CHECK: Stokkemask update speeds are wrong if web interface is also open
  • Grand: uMPX crash with wrong PID selected on satellite - email 17 april 10:29
  • Web interface doesn't show active preset, and doesn't properly sort them, and doesn't remember the setting of how to show it
  • 75us FM preset did not turn FM, Stereo, RDS on
  • For Pi 5, check that it's configured properly for Pi 3/4/5 speeds!
  • For Pi 5, change default block size to 4096! ->
  • Noise gate gets stuck in ARM build - see support ticket Fixed, TEST
  • For Pi 5, change default default # cores from 3 to 4 -> Fixed, TEST
  • VERIFY: Text fields are broken!
Latest version - Beta 10.53-031 (June 15 2025)
Changes/bugfixes
  • Vorbis streaming should work again on all OS's
  • French translation files are included again (there was a problem with UTF-8 characters in the file name)
  • PiMP GUI must have been somewhat broken in 10.51. Solved.
  • Pi image binaries were built without support for software updates! Solved.
  • All warnings in all builds are gone now.
Latest version - Beta 10.53-028 (June 12 2025)
Changes/bugfixes
  • Adaptive Compressor/Multiband: Just fixed a really nasty bug which could cause constant NAN's, if you were using the Adaptive compressor mode in the multiband compressor, and the first band was set to Peak but any of the others to RMS, and Band linking was on, and Limit CPU was set to anything else than Pi 3 or Unlimited.
  • MicroMPX on Linux had a dependency to libjack, removed.
  • Added logging of search directory when trying to load librist.dll on Win32 (stand alone *or plugin*, which fails for someone)
Latest version - Beta 10.53-026 (June 11 2025)
Changes/bugfixes
  • Hid "User rights" popup for nonexistent users in "Accounts" overview page
  • Lots of small build system fixes
  • Web interface in 32 bit Pi MicroMPX does not work (Jeroen) - Not confirmed, works fine here
Latest version - Beta 10.53-024 (June 6 2025)
Changes/bugfixes
  • Lots of "under the hood" changes. Vorbis logging added, so if people are having issues with Vorbis, please let us know what the console window shows when you try to enable it.
  • Mac VST2 does not load in OcenAudio (Mathijs, Intel) - fixed, unknown why
Latest version - Beta 10.53-022 (June 4 2025)
Changes/bugfixes
  • Streaming should now work on all OS's (I hope), including all supported codecs
  • MicroMPX performance on ARM is now same as with old build
  • MicroMPX no longer uses "fmt" library for formatting the logging. This might affect performance. (Not yet measured)
  • MacOS WatchCat should work now, both Intel and M1 Mac
Latest version - Beta 10.53-020 (May 31 2025)
Changes/bugfixes
  • RIST should now really work from Stereo Tool
  • Lots of build issues fixed (there's still a list, but it's not insanely long anymore)
  • A lot of "under the hood" code improvements in the scope/spectrum drawing code (subtle improvements in behavior)
  • WatchCat on Mac builds, but signing doesn't work (I expect there's an issue with *any* signing since today), so we can't post it yet
Known issue: Streamling libraries don't load on all platforms. We'll look into that soon.
Latest version - Beta 10.53-018 (May 28 2025)
Changes/bugfixes
  • ARM 32 bit versions are working now (compiler bug)
  • MicroMPX on Windows was broken due to compiler bugs, only playing squeeking sounds. Fixed.
  • WatchCat for Windows is back! (Mac still to be done)
  • VST plugins: Windows version was building with wrong compiler flags.
Latest version - Beta 10.53-015 (May 24 2025)
Changes/bugfixes
  • Linux: Replaced deprecated jack call
  • macOS: Setting file now follows executable name just like for Windows and Linux
  • Build: macOS VST3 and Linux-x64 libStereoTool are finally building
  • AES67 stream discovery threads did not properly close on program end
  • Console Linux 64 bit versions were not being built
  • All files should now be generated with the correct CPU flags (including all sub-libraries for cross compilation targets)
  • Build: Tests are working again (slightly hacky with _Exit(0))
  • Build: libmp3lame.so does not load on Linux-x32 and x64, why?? Mac ARM versions are fine (Intel and ARM Linux to be tested)
  • Added clearer warning message if streaming libraries don't load (Linux, Mac)
  • Added "Start with Linux login" support - does start Stereo Tool after logging in. Nothing yet without logging in, and this is with-GUI-only for now.
  • Matrix mode "Never reduce stereo" now available in Adaptive and Advanced AGC
Latest version - Beta 10.53-012 (May 20 2025)
Changes/bugfixes
  • RIST support for MicroMPX is back!
  • Stereo Reverb did not switch off in Bypass mode
  • DeReverb in BIMP didn't trigger unlicensed message
  • AGC Window in Adaptive mode was fully broken. Now it works. There are some open issues (waiting for feedback Mathijs)
  • MicroMPX test switching versions and make sure that decoder works. -> Switching did not force a reset, caused confusion in decoder.
  • MicroMPX: Fixed a possible stability issue when recovery packets were received with an invalid packet number.
  • MicroMPX: RIST is back; we support Advanced profile but not yet Simple (so we're not compatible yet with RIST in 2wcom encoders/decoders)
  • MicroMPX: RIST 'socket error' recovery could fill up all possible 'slots' and slop working (in earlier beta's, after multiple months).
  • Bug in earlier beta's: AES67 detection was continuously retrying to connect.
  • New build: Mac versions had dependency to external library that nobody has, solved
  • New build: Mac stand alone had wrong link to AAC encoding library
Latest version - Beta 10.53-009 (May 13 2025)
Changes/bugfixes
  • Loads of build changes
  • Mac builds are working
  • MicroMPX: GPS state display had wrong style, now green if locked, red if not.
  • libStereoTool Win64 has Intrasonics support, FOR TESTING ONLY, not yet certified.
Latest version - Beta 10.53-007 (May 8 2025)
Changes/bugfixes
  • ARM 32 and 64 bit builds are working, except customer-specific cross-compile builds
  • Add building of helper applications (STXtreme software, build compare functions, .ci file generators)
    Not build related:
  • AES67 output is back - and now with time smoothing added to handle jitter on PTP clock. Should be fully functional now.
  • Important bug in 10.51: No preset is loaded on initial startup!
  • MicroMPX namespace: Make identical to library names to prevent linking/runtime errors when linking both Stereo Tool and MicroMPX. -> That wasn't the problem
  • Add new Adaptive Bass Monster - Dense preset, and make it the default
Latest version - Beta 10.53-006 (May 4 2025)
Latest version - Beta 10.53-004 (Mar 17 2025)
Changes/bugfixes
  • Console window closes after starting ST from it
  • Executables have no icon
Latest version - Beta 10.53-003 (Mar 16 2025)
Changes/bugfixes
  • Streaming in 64 bit builds fixed. (Title bar still says BETA002).
Latest version - Beta 10.53-002 (Mar 16 2025)
Changes/bugfixes
  • Fixed crashes in 10.53 BETA001 (Natural Dynamics, among others), which also caused "Audio data lost" messages.
Latest version - Beta 10.53-001 (Mar 16 2025)
Changes/bugfixes
  • Moved Windows build to new build environment
  • Bug fix: Settings to disable some warnings were missing in the GUI since 10.51, restored.
PostPosted: Sun Mar 16, 2025 10:39 am
Somewhat confident wasn't enough just yet, as it (x64) starts up with lots of error messages. Also can't quit the program other than by killing it through TaskManager :-(
PostPosted: Sun Mar 16, 2025 11:12 am
Ugh... Which exact version are you testing, and can you post those error messages here?
PostPosted: Sun Mar 16, 2025 12:03 pm
It's the version you uploaded this morning. Various error messages appear, of which "A piece of audio was ignored ..." repeatedly returns. See attachments. Version BETA1051-011 (x64) runs totally fine though. Running W10 22H2.
PostPosted: Sun Mar 16, 2025 2:06 pm
Thanks! I just received another report about the "A piece of audio was ignord"; they sent me their settings and it reproduces here (it also won't close). So we can look into it. Once that's fixed I'll check if we can reproduce that BB issue, but that's far less worrysome.
PostPosted: Sun Mar 16, 2025 5:08 pm
Here, I'm getting the ignored audio error ad nauseum after I get the BB error; which for me is caused by Natural Dynamics.
PostPosted: Sun Mar 16, 2025 6:35 pm
It looks like some optimizations in the new chain cause crashes. This may also cause other issues after that. Trying to fix it now. This might take a few iterations.
Edit: Yup, and they in turn caused the "A small piece of audio..." messages as well, apparently. Building an update now.
PostPosted: Sun Mar 16, 2025 7:35 pm
May the Optimization Gods be with you!
PostPosted: Sun Mar 16, 2025 8:18 pm
BETA002 posted. Someone sent me a .ini file that caused both exception messages and lost audio messages; both are gone now, at least with that preset.
PostPosted: Sun Mar 16, 2025 10:23 pm
BETA003 posted. Streaming now works in 64 bit.
