Thanks for explaining the dequantizer...
The 7 Wonders preset in the latest 8.01 beta, does not use the pre-ringing killer. I turned it on, for my Internet radio station, but turned the level down from 200 percent to 100 percent.  I was just curious as to why it was not being used?
Dequantizer is really filter for repair things (if you know what it does) and not something that will i use on every day processing.
99.99% of tracks does need it, so as usuall it would have negaitve effect to fix something that does snot need fix at all.
Delossifier i use, now always. Simply said, it fixes a bit that mp3ish sound.
I even use "Spectral Hole Filler" lately. But only for streaming!
