 Post subject: RDS Centred Name
PostPosted: Thu Nov 12, 2009 8:07 pm
I have a short name for my station and use the space bar to centre the text.
However, every time I restart winamp the text moves back to position one and it then left aligned.
Any way to force it to be centred?
Thanks!
 Post subject: Re: RDS Centred Name
PostPosted: Thu Nov 12, 2009 9:40 pm
how exactly did you write txt?
PostPosted: Thu Nov 12, 2009 11:11 pm
Oops, that seems to be a bug. I'm using some Windows call to store the text in a file, but apparently it removes the spaces when it reads it back...
Possible workaround:
Put "1.5s:" in front of it, so for example
1.5s:   ME
instead of
   ME
Actually this tells the RDS encoder to show the text for 1.5 seconds before moving to the next text (if there is any), 1.5 seconds is the default value so adding "1.5s:" has no effect - but the first character of the string is not a space anymore.
