PostPosted: Fri Oct 10, 2008 12:31 pm
Hi all,
I've created 3 different .sts files, all with vastly different settings.
1. Preamp at 40
2. Equalizer with everything boosted to the highest level
3. Preamp at 10
When I use the command line, it says it's reading the settings file, but the output wave file is always the same.
I even use a CRC checker and it confirms the files are identical.
Am I doing anything wrong?
PostPosted: Fri Oct 10, 2008 12:45 pm
In the command line version, you must always specify the full path to the .sts file. So: Not x.sts or .\x.sts, but C:\YourDir\x.sts .
If you don't it will read the global (Winamp) .ini file.
Please let me know if this solves your problem.
PostPosted: Fri Oct 10, 2008 12:55 pm
Brilliant. Fixed the problem right away. :)
Thanks!
