PostPosted: Tue Jul 12, 2016 3:03 pm
Has anyone tried it? The particular machine that I'm interested in is
http://www.newegg.com/Product/Product.a ... 6883722001
It has Atom Z8500 on board and is possible to install Windows 10 (and, maybe, others?)
I plan to hardwire this via the HDMI output to my car's dash player and run Stereo tool for sound processing (and, maybe a modded Winamp with good crossfader).
PostPosted: Tue Jul 12, 2016 4:30 pm
Since it has 4 cores, wait a few days and then get the latest beta - I'm working on a processing framework redesign that can use more than 2 cores. (It appears to work now but there are probably still some bugs in it).
PostPosted: Tue Jul 19, 2016 2:47 pm
i wonder if that will run stereo tool for linix so would boot up with the car and run like a normal stereo for just processing
PostPosted: Tue Dec 06, 2016 8:02 pm
Hi sorry for the bump the topic, but I myself am using a small computer UP BOARD http://www.up-board.org/up/ plus sound card CMedia https://hifiduino.wordpress.com/2013/04/03/c- media-cm6631a-based-usb-2S-interface /, impressions and how best to generate MPX easily plus RDS. Delay on the border proven wrong. of course, I listen to the stream in stand alone mode. CPU usage of approximately 60-80%, RAM 1 Giga.
sorry for my english i translate to google.
PostPosted: Fri Feb 17, 2017 9:22 pm
Did anyone try Stereo Tool with Celeron N3450 or J1900?
I'm especially interested if those CPUs are capable of running the Busybox preset, at least on 50% CPU quality.
Especially the N3450 is interesting to me because it runs below 10W TDP.
PostPosted: Tue Mar 07, 2017 11:10 am
I did try on a Celeron N3150, and ist was *just* OK. Couldn't use all the fancy processing steps like DC and ND without reducing quality.
PostPosted: Fri Mar 10, 2017 10:06 am
Thanks! What preset did you try? I'm especially interested in the Busybox and Phantasy FM presets (without FM modulation and delossifier for web radio streaming).
But if i understood correctly if I'm okay with say 40% quality then it will work and might even able to run a scheduler next to it (like RadioDJ).
PostPosted: Fri Mar 10, 2017 11:58 am
Just for info, with some tweaking (slightly reducing the quality of the declipper and the composite clipper, not using Stokkemask, Quality at 40%, 'Ignore High Frequencies' on) I've managed to run full FM presets with stereo/rds and composite clipping on a Raspberry Pi 3.
This helps: Turn "MULTICORE" *OFF* (yes I said off!!) but set Threads to the number of threads in your pc.
Note: Latency will be considerably higher than on faster systems. If that's no problem, this should work.
PostPosted: Sat Apr 01, 2017 6:33 pm
Sorry for not responding earlier. I tried Bojcha's HD settings on the N3150, no FM processing.
