 Post subject: Sesame
PostPosted: Sun Jun 26, 2016 11:57 pm
Hello!
Here is (still beta) preset that i am working on.
For first time i tried to make as much as possible really open preset but to keep processing at some decent level.
Also way less range in MB then i usualy do, (Got some compliments from many) so i also put my goal to that too.
Sesame_06_HD.sts [93.95 KiB]
Downloaded 1076 times
Sesame_RC1.sts [86.01 KiB]
Downloaded 769 times
Release Candidate 1
Sorry for delay and not finishing preset. Mostly i waited some crucial things to be changed/fixed in ST.
One of main problems is AGC, especially with "open" presets like this. This time i done some workaround and maded "Dual WB AGC"
All crossovers revisited, all limiters rechecked to get maximum from them, still problem with "WB limiter" tho.. etc
I will recheck few more things before final release.
After final release will be FM version. Please do not use HD version for FM.
Let me know if you find some strange behaviour :)
 Post subject: Re: Sesame
PostPosted: Mon Jun 27, 2016 1:11 am
Sesame its a nice name!
PostPosted: Thu Jun 30, 2016 9:21 am
Hi Bojcha,
in general I like the behaviour of your new preset.
Unfortunately, unlike in your other presets (especially in my favourite "unveil") I also notice a disturbing ringing in the high frequencies.
It sounds very digital. Can you add more of an analog touch to it?
Cheers
Mike
PostPosted: Thu Jun 30, 2016 12:51 pm
Still need to check since i got some reports that older presets for some reason does not sounds same in new versions of ST.
PostPosted: Sun Nov 13, 2016 11:17 pm
Are you still working on this? What's the latest?
PostPosted: Sat Dec 10, 2016 3:12 am
Updated first post.
PostPosted: Sat Jan 14, 2017 1:18 pm
...can't wait for an update ;)
