 Post subject: Stereo Tool & VLC Stream
PostPosted: Sat Jun 11, 2016 7:29 pm
Has anyone gotten stereotool to actually stream via vlc?
We are a commercial FM radio station using StereoTool to process our FM signal. However, I would like to use stereotool as the encoder for our STL as well. I would like to use AAC+ as the codec. But I cannot get it to stream to a Barix exstreamer (nothing happens).
Any help? I've read the help guide
PostPosted: Sat Jun 11, 2016 7:57 pm
I've spend some time on trying to achieve this also, but I didn't had any succes on it.
It seems that vlc is not capable of encoding to AAC+, so now i'm using virtual audio cable and Altacast(with AAC+ encoder)
PostPosted: Sat Jun 11, 2016 11:31 pm
Where did you find an AAC+ encoder for Altacast?
PostPosted: Sun Jun 12, 2016 6:02 am
Hey firecasey,
Message me directly and I'll discuss with you.
PostPosted: Sun Jun 12, 2016 5:01 pm
I don't know where I found it, it was somewhere on the internet ;)
I don't know if are free codecs and it's allowed to post them here, but otherwise I can send them to you.
Hey firecasey,
Why not discuss it here so other people can also benefit from it?
If it is possible to stream AAC+ directly from vlc I and I think more peapole with me are also interested.
