PostPosted: Wed May 18, 2016 1:23 am
Loud, yes. Not squished too far.
Im new here, new to stereotool.
Johnny Iroc
Program Director
Hard Rock Radio Network
Peru IL
STOOL5-16-16.sts [93.37 KiB]
Downloaded 518 times
PostPosted: Wed May 18, 2016 12:17 pm
Welcome here on ST forum Johnny :)
I listened to your preset, it need a lot of work unfortunately, but that's just the great thing from this processor.
It's a real challenge and learn-full how things work in audio processing.
I'm not sure how you make your preset, I mean what gear U use, headphone, pc speakers, monitors?
Key is to have a good headphone and monitors, pc speakers is also a good reference if your preset is at the final stage.
another tip, is to listen how the music sounds before it goes into StereoTool (with bypassing it) if it goes out worse than it goes in, you have work on it.
a preset isn't ready in a few hours, but tweaks are needed, because your ears get used to processed sound. a day later it can sound totally different than the day before.
So we speak in days, even months in my case, everytime there is a upgrade, audio can sounds different. Hans always tweak the software, so that is also a thing you have watch.
Try for instance the build in presets from StereoTool to get a better idea, how things really works,
Success :)
