Post new topic  Reply to topic  [ 25 posts ]  Go to page 1 2 3 Next
 Post subject: Which sound card?
PostPosted: Wed Oct 28, 2009 8:12 pm
Hello to all.After testing your great software just a little I realize that my on board sound card is a little old...Because I would like to try the Stereo and RDS functions(later) I think I have to start from a good card.Well here it is:
http://www.thomann.de/gr/search.html?xs ... hk54767=on
They are identical except the cheaper one has better converter, right?Well what do you think?
Thank you!
 Post subject: Re: Which sound card?
PostPosted: Wed Oct 28, 2009 9:07 pm
Just get Juli@ and enjoy.
And...
Juli@ is 192kHz ! on link you provided is mistake!
http://www.esi-audio.com/products/julia/
* 2 analog input channels, 2 analog output channels
* 24-bit/192kHz AD converter with 114dB(a) dynamic range
* 24-bit/192kHz DA converter with 112dB(a) dynamic range
* swappable socket (Unbalanced RCA with -10dBv or Balanced TRS with +4dBu )
* coaxial S/PDIF digital input
* synchronisation to digital S/PDIF input signals
* optical S/PDIF digital output with automatic shutter (max.96kHz)
* coaxial S/PDIF digital output (max 192kHz)
* support for DirectWIRE 3.0
* 4 inputs and 4 outputs can be used with 24bit/192kHz simultaneously (incl. MIDI I/O) - full duplex
* PCI card is compatible with 3.3V and 5V PCI slots
* independent monitoring control for analog and digital input signals and playback
* EWDM driver: MME, DirectSound, ASIO 2.0 and GSIF 2.0 support
* Windows 98SE/ME/XP/2000/Vista/7 compatible
* compatible with Mac OS X 10.1 and newer
* Linux compatible (ALSA)
PostPosted: Wed Oct 28, 2009 9:14 pm
Oh OK then...It looked strange to me because I've read that sound card should be 192Khz
Thank you.
P.S You are using that card right?If I don't use stereo option (I have a hardware coder, it's a DIY pcb but works pretty well,at least it sounds qood),do you think it will improve sound over an intergrated sound card?Is it worth buying?
PostPosted: Wed Oct 28, 2009 9:30 pm
Yes we use Juli@ on our local transmitter. Before that we use Realtek Onboard Souncard (ALC889 chip).
First you must tell me what soundcard onboard You have, but anyway Juli@ is always better then any onboard souncard.
Second, i don't know how your hardware coder works .. but i am sure when you put Juli@ and StereoTool's MPX output i think you'll be surprised by audio quality.
In that configuration you have RDS and Clipper too.
PostPosted: Wed Oct 28, 2009 9:42 pm
My sound card is a Realtec AC97 onboard card.I think it is a standard card with limited capabilities,right?
PostPosted: Wed Oct 28, 2009 9:44 pm
Yes, it's only 48kHz I/O.
Realtek Soundcard with 192kHz output is marked "HD"
PostPosted: Wed Oct 28, 2009 9:48 pm
Ok thank you.Now that I've found you, please tell me another thing:
Will every card marked HD work?I mean not now but in the future if I decide to add Stereo and RDS?Thank you very much.
PostPosted: Wed Oct 28, 2009 11:08 pm
As far as i know..
Realtek habe HD Audio onboard cards and Analog Devices known as SoundMAX HD audio.
Basicly mean they are 192kHz output, and that is needed for MPX output.
PostPosted: Wed Oct 28, 2009 11:22 pm
OK,thank you
PostPosted: Thu Oct 29, 2009 12:12 am
In addition, there ARE 192 kHz sound cards that don't work. Anything from Creative (SoundBlaster / X-Fi) really doesn't work. But as far as I know (which is only what is reported in this forum, so it's not really a lot) others should work.
Hint: Check some hi-fi lovers forums. Usually, if they really love a card, it's very good (check the Juli@ in those forums and you'll see what I mean).
