 Post subject: Less DELAY????
PostPosted: Sat Apr 02, 2016 8:24 pm
Hi all guyz and sorry about my English.I am Greek.
I have stereo tool version 7.50 (standalone).
my pc(stereo tool) requiments are here:
4core Intel.
4Gb RAM DDR2
WINDOWS 7 64BIT.
So, I have one pc for playing music and the LINE OUT from this pc to another pc(for Stereo Tool).I use it for FM transmitter,stereo encoder & rds.
All are perfect but i have DELAY.WHEN I BYPASS STEREO TOOL I DONT HAVE.MY AUDIO CARD IS REALTEK AND I HAVE OUTPUT 192 & 24BIT.
Can anyone tell me please how to reduce delay?
Please Help!!
Thank you all
 Post subject: Re: Less DELAY????
PostPosted: Sat Apr 02, 2016 8:55 pm
Reduce buffer size on "Normal Output" or "FM Output", whichever you use. Also try to reduce latency in the "CPU and Latency" menu.
PostPosted: Sat Apr 02, 2016 10:49 pm
First you need to set soundcard to 192kHz and 16bit. Also in windows>control panel>sound, both playback and recording.
Try to reduce FM output buffer as much as possible as already said.
Also do not expect super LOW delay! That's only possible with ASIO. So you need ASIO soundcard.
PostPosted: Sun Apr 03, 2016 9:36 am
Thanks for all!your opinion about Xonar Asus u1?
