Preset Calification
Excellent 0%  0%  [ 0 ]
Very Good 50%  50%  [ 1 ]
Good 50%  50%  [ 1 ]
Bad 0%  0%  [ 0 ]
Very Bad 0%  0%  [ 0 ]
Total votes: 2
 Post subject: SmartChanges by GAP
PostPosted: Mon Jan 18, 2016 4:44 am
A simple and "smart" Sound! ;)
GAP_SmartChange_v0.1.sts [90.87 KiB]
Downloaded 531 times
by GAP
"Less is More" (Bob Katz)
 Post subject: Re: SmartChanges by GAP
PostPosted: Mon Feb 01, 2016 5:20 am
Update Preset to v0.2! ;)
Enjoy It.
GAP_SmartChange_v0.2.sts [91.31 KiB]
Downloaded 525 times
by GAP
PostPosted: Wed Feb 24, 2016 3:55 am
Update Preset! ;)
GAP_SmartChange_v0.3.sts [91.8 KiB]
Downloaded 466 times
by GAP
PostPosted: Fri Feb 26, 2016 10:50 pm
To be honest, I did like your Dominator preset a lot more, I even used it for a time on my stream a few years ago.
I miss punchy bass, you can avoid this by adjusting attack settings (also from multiband limiter), just move the slider more to the right in the area from 45Hz to 500Hz, I also see a dip on 250Hz area from a few db. I tried to killed this gap for a long time, but with the new versions of ST they disappeared, also on the 500Hz you had this in the past.
But watch out for overshoots, same with single band settings, you could burn the clipper with that and would kill your sound.
Mid, mid high are great, very soft and good presence. Love that part. Just keep tweaking and it will be ok I'm sure.
Good luck :)
PostPosted: Sun Feb 28, 2016 7:21 am
Thank you very much GuntherM for detail as precisely the failures of the preset.
He was experimenting with bass other options, but it really was not convinced yet, if he was with the mids and the high.
Now I have made several changes, mainly in the lower part of the spectrum, and I start to like.
Modify the low bands, it was very short the first band, the coupling was also very high, with 9-band becomes more sensitive. I've also adjusted some times and limiter levels.
Leave a new version and I would like your opinion, I would also like to hear your stream (you pass me the link?)
GAP_SmartChange_v0.4.sts [90.77 KiB]
Downloaded 470 times
by GAP
PostPosted: Fri Mar 04, 2016 4:16 am
New Version! ;)
GAP_SmartChange_v0.5.sts [90.83 KiB]
Downloaded 417 times
by GAP
PostPosted: Sat Mar 05, 2016 4:42 am
Sorry for the speed update, but I wanted to finish the adjustment that had begin in the previous version.
This is to release as much as possible all the bands and control them very smoothly overshoots, expecting a very transparent, consistent and sound very presence.
You will say if you've accomplished and discuss what they believe is missing (... or are in more :) )
GAP_SmartChange_v0.6.sts [90.1 KiB]
Downloaded 483 times
by GAP
PostPosted: Sun Mar 06, 2016 4:53 am
Will listen tomorrow, my ears are now down from my own presets.
Fatigue from high pression levels and than you can't listen well to another preset.
PostPosted: Mon Mar 07, 2016 1:04 am
No problem :mrgreen:
by GAP
PostPosted: Mon Mar 07, 2016 1:58 am
Fixed some excesses of the band 8 and some minor details. ;)
GAP_SmartChange_v0.7.sts [90.11 KiB]
Downloaded 497 times
by GAP
