 Post subject: Passive Aggressor
PostPosted: Wed Dec 30, 2015 11:54 pm
For FM. Keeps the program nearly untouched, beside declipping and a little bit ND for heavy mastered material, to put it in the right direction. Adds a little bit of warmth and punch to it (with MB1, very loose Attack/Release), also controls (mainly) very heavy highs softly (with MB2). X-dBr-Versions with BS412 with different FM-loudness levels enabled. The type of processing that you don't recognize, until you turn it off!
Created, because I always missed such a preset in the bulit-in FM-ones, which are mostly balls-to-the-wall :D
Passive Aggressor.sts [80.18 KiB]
Downloaded 534 times
Passive Aggressor 3 dBr.sts [80.17 KiB]
Downloaded 466 times
Passive Aggressor 0 dBr.sts [80.19 KiB]
Downloaded 507 times
 Post subject: Re: Passive Aggressor
PostPosted: Tue Jan 05, 2016 4:55 pm
Don't know if you know, but this name was originally used by Jessie Graffam on Breakaway/Omnia.9 presets. I don't know and can't speak for him, but I'm not sure he'd be into you using that name.
