Post new topic  Reply to topic  [ 25 posts ]  Go to page 1 2 3 Next
 Post subject: OPTIMOD SOUND IS HERE !
PostPosted: Thu Dec 24, 2015 7:33 am
Ok,
Well as jou might know in Holland all big stations are running Orban Optimod's and with it's particular wooly and punchy bass it produces it has a signature sound.
I have tried for almost 2 jears to recreate this sound (because i like it :D) and sometimes i came close, but my latest preset is realy something you should listen to.
Please download latest beta version here: viewtopic.php?f=14&t=7188&start=60
Hans included my new preset: Jeroen Platenkamp - SUBLIME
EDIT: PLEASE SET LATENCY @1024; SET INPUT LEVEL @ ABOUT 60% OF INPUT VU
EDIT2: JUST ADDED ALL AUDIO SETTINGS FOR THIS PRESET
Jeroen Platenkamp - SUBLIME AUDIO SETTINGS.sts [84.59 KiB]
Downloaded 3760 times
SUBLIME is my personal attemt to come as close to the Orban Optimod's as possible, in fact i personaly like it more than the Orban units.
So for all you guys who are into Orban, please check it out and SUBLIME will probably be a good starter for tweaking to your own transmitter.
I would love to know what you think about it, please leave your comments below.
Finaly best wishes for you all and a good and healthy 2016 !
Jeroen.
PostPosted: Thu Dec 24, 2015 12:27 pm
Hi Jeroen,
will you make a HD-(Web)-Version of this preset?
Cheers and Merry Christmas
Mike
PostPosted: Thu Dec 24, 2015 1:53 pm
Hi Jeroen,
Mike
Hi Mike, I probably will, but first some family gatherings the comming days ;)
PostPosted: Fri Dec 25, 2015 5:49 am
Sounds great! definetely got the orban sound, but the highs are hissing a bit.
I would love to see a version of this that works without the need for the paid declippers and such.
The Buzz - Central Alabama's Alternative Rock Station
http://thebuzzmontgomery.com
PostPosted: Sat Dec 26, 2015 3:25 am
Jeroen, is there a reason why the Normal output is so much softer than the FM output? The difference is more than 8 dB, and for Normal output you don't even have pre-emphasis.
And, what happens if you leave the latency at 4096? I can put 1024 in the built-in version if needed... but I know that among others True Bass functions far less good at 1024 than at 4096.
PostPosted: Sat Dec 26, 2015 9:14 am
Good morning Hans,
Answeres to your questions:
- No, the preset was made for FM. Never did anything with the other outputs.
- I found the bass somewhat more punchy in 1024, so my peronal view is to leave it in 1024.
Everybody is free to adjust all settings to their own needs, so if 4096 is preferred by others no problem.
If you want me to adjust settings for other outputs please let me know.
Jeroen.
PostPosted: Sat Dec 26, 2015 9:36 am
Hans, do you mean the web version of sublime? The reason why those a lot softer sounds I have found Relative loudness is non-FM-12.04 dB and must stand on 0.00. Look the picture!
Edit: Sorry for the bad englisch i use a translator!
PostPosted: Sat Dec 26, 2015 11:38 am
Ah Daniel thanks for that one, missed that slider completely !!
What do you think about the sound ?
@Hans, could you set the slider to 0.00 in the next build ?
Have a nice 2th X-Mas day you all !!
Jeroen.
PostPosted: Sat Dec 26, 2015 12:34 pm
Ok changed for next build.
PostPosted: Fri Jan 01, 2016 11:15 pm
The sound is very good, however, I'd like a bit more bass and lower mids. Where would you advise making that adjustment?
videojohnh
