Post new topic  Reply to topic  [ 32 posts ]  Go to page 1 2 3 4 Next
 Post subject: 7wonders
PostPosted: Mon Dec 07, 2015 7:32 pm
Brand new preset and multiband logic!
HD only.
7wonders_v024_3L_web!.sts [93.07 KiB]
Downloaded 1304 times
ST 7.84+
7wonders_v027_web!.sts [93.06 KiB]
Downloaded 1886 times
Version .27 - fine tuning of everything. AGC back to 4096 mode.
feedback appreciated! :)
 Post subject: Re: 7wonders
PostPosted: Tue Dec 08, 2015 12:22 am
going to compare this to mine on my 3 streams tomorrow...will write then!
PostPosted: Tue Dec 08, 2015 12:37 am
ran a quick comparison on my country stream.
Very open and clean. Probably my favourite of any presets thus far.
Interesting how you used fast attack speeds and then slow release times.
PostPosted: Tue Dec 08, 2015 1:41 pm
Super preset. :)
There's something silky about it, especially on vocals.
PostPosted: Tue Dec 08, 2015 8:36 pm
this is considerably better sounding than the preset I've been working on.
on two of my streams I had to turn off the declipper and natural dynamics. on the country stream I've registered both so using it there.. so I'll have to listen and see if I like it as much without the declipper and ND.
so I'm running your preset now on 3 of 4 of my streams here at work...will do some long term listening and report back.
I'm really surprised how "complex" this preset is, with how many of the compressors you are using.. (all of them!).. it really sounds clean and not horribly over processed to my ear.
Sean
PostPosted: Thu Dec 10, 2015 2:11 am
Thanks guys!
Updated to version .27!
PostPosted: Thu Dec 10, 2015 3:28 am
I'd avoid using the ! in the filename. Causes havok with windows.
Otherwise, AWESOME preset!! Thanks!
PostPosted: Sat Dec 12, 2015 12:13 am
Really nice! :ugeek:
PostPosted: Thu Dec 17, 2015 8:58 am
With a few FM soundcard and FM Transmitter checks it sounds even greater. Thank you for a very divine preset.
PostPosted: Thu Dec 17, 2015 4:31 pm
Nice preset, using for FM with small mods...
7wonders_v027_FM_mod_by_GB.sts [93.11 KiB]
Downloaded 991 times
https://fmfeeling.com
