 Post subject: Analog skin
PostPosted: Sat Nov 28, 2015 6:44 am
...with meter movements instead of lightbars. It would be neat for "old'school" formats! Is there an SDK for ST skins?
 Post subject: Re: Analog skin
PostPosted: Sat Nov 28, 2015 8:11 pm
You can only replace the bitmap images at this moment. So there's no way to replace bars by analog meters. For meters, all you can do is change the colors.
You can take one of the existing presets from the forum and modify it. (Hm, I thought I had posted the original preset here as well, but I don't see the post).
