Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 97 posts ]  Go to page 1 2 3 4 510 Next
 Post subject: Stereo Tool 7.82
PostPosted: Sat Nov 14, 2015 5:18 pm
Stereo Tool 7.82 is released!
Changes 7.82:
  • Bug fix: In 7.80 Automatic restart could be triggered incorrectly when the buffer size was very small.
  • Bug fix: Fixed some small issues caused by the Thimeo framework rewrite, had no effect.
Changes 7.81:
  • Bug fix: In 7.80 64-bit versions, text entrance fields showed * instead of characters.
  • Bug fix: In 7.80 non-phase linear highpass filter didn't work.
  • Bug fix: In 7.80 low latency phase rotation filter didn't work.
  • Bug fix: In certain cases, Automatic restart could keep restarting after sound card problems.
 Post subject: Re: Stereo Tool 7.82
PostPosted: Sat Nov 14, 2015 5:27 pm
Version 7.82 shows 7.81
Edit: It's ok now maybe i download to fast
PostPosted: Sat Nov 14, 2015 5:38 pm
PNR Noise & Hum still doesnt work with VST (Wavelab6)!? :(
PostPosted: Sat Nov 14, 2015 8:06 pm
Stand Alone download links are for 7.73!
PostPosted: Sun Nov 15, 2015 2:04 am
Oops, fixed!
PostPosted: Sun Nov 15, 2015 2:22 am
Bug report:
- True Bass is called WARM BASS in the LOAD/SAVE pull-down. WB in menu at bottom should be TB.
- Separately processed streaming output: Lowpass frequency not displayed correctly.
- GUI: Pre-emphasizing for MP3 is disabled - shouldn't be (unknown if it works).
- Update from version 7.40 with Simple Clipper disabled, Amplification set to 0 and Pre-limiter enabled causes silence in output in 7.50+.
- Crash while continuously (for a really long time) adjusting Buffer size, complete hangup: http://i.imgur.com/06jenht.png
To add:
- Add clipping at 75 while BS412 limiting at 50, for stations that stream using a lossy codec to their transmitter site.
- Add Generic plugin function to set parameter values.
PostPosted: Sun Nov 15, 2015 7:04 am
Red bar CPU report from me is still present when you listening an external input stream with VLC (Stand alone 32 bit, probably in 64 - cannot test it). See the picture.
PostPosted: Sun Nov 15, 2015 11:02 am
Also the text WB on the meters is confusing, should be TB.
PostPosted: Sun Nov 15, 2015 8:11 pm
Nice new version Hans . Keep up the good work. But there are two main problems . I have hiccups every second or so and the cpu meter shows very very large numbers (in the order of 70% on an i7-4790k for non-fm presets).
My radio station
http://amradio.ddns.net
PostPosted: Sun Nov 15, 2015 8:42 pm
I will check the CPU load against older versions tonight! (Not @ home now)
