Decided to mess with the bass boost on your preset to get even more of a deep kick; I find these settings worked well:
[Bass Boost]
Clip level=2.5
Difference=0
Drive=0.439999998
Enabled=1
End lowpass frequency of input filter=77
End lowpass frequency of output filter=250
Preserve louder peaks=1
Start lowpass frequency of input filter=27
Start lowpass frequency of output filter=120
Strength=3
Well ive been trying your bass boost settings for up to 3 hours in many types of music(i.e House Music,Trap,Rock,Pop and so on) and i have to admit bass sounds very nice!
Ive tested with EQ too and i saw as you said a lot of clipping.
I changed the EQ and Bass Boost settings a bit to minimize the clipping.
If you want give it a try and tell me your opinion
