 Post subject: Low Khz deviation
PostPosted: Sun Nov 08, 2015 4:22 pm
On my first (very brief) test using ST to drive my transmitter, I could only max out at 32 Khz deviation.
I've bumped the Marian Trace Alpha output from +15 to +18 dBu.
Where else shall I look?
 Post subject: Re: Low Khz deviation
PostPosted: Sun Nov 08, 2015 5:06 pm
Probably exciter input level.
PostPosted: Sun Nov 08, 2015 6:09 pm
If you mean the transmitter itself, I tried that, didn't do much...
PostPosted: Sun Nov 08, 2015 9:54 pm
Success! I increased the MTA input (Analog 1-2) +7.5; all faders at zero; then had to turn my transmitter level up by "5" CW to get from 50 khz to 75 khz.
For the record: running ST 7.74 beta027, preset: Analog Pleasure FM (hvz), into BW transmitter TX300 v2.
PostPosted: Sun Nov 08, 2015 11:57 pm
Odd, even with my Realtek (which is probably much softer than the Marian) I need to lower the level to about 30% (-10 dB or so).
RVR LCD30.
PostPosted: Mon Nov 09, 2015 5:12 am
it makes me wonder if my air chain is a little on the soft side... but this was recommended going into my audio switcher.
For the record, my airchain for testing ST was Rivendell automation -> ASI 6044 card -> BT switcher -> Behringer SPL 3220 (limiter bypass) -> Henry Patchbox -> Marian Trace Alpha -> ST as above.
Only the Behringer and MTA are easily adjustable (not counting ST), and the Behringer is pretty straightforward.
