PostPosted: Fri Oct 30, 2015 6:21 pm
Anyone had this problem? And a solution?
I turn on my pc, I open the Marian Trace Alpha mixer -> NO input signal on the meters.
I reboot the pc -> Input signal on the mixer.
Tried Marian drivers 2.8.7.0 and 3.0.1.0
Windows 8.1 pro, 64 bit, SSD
Intel i5-4670k, cpu@3.40 GHz
Ram 4,00 GB
PostPosted: Sun Dec 13, 2015 2:51 pm
Marian has some issues under latest WIN versions, please read below:
7. Attention: Changes of Shutdown in Windows™ 8.x and Windows™ 10
Windows™ 8 introduces a so called "Quickstart". It's active by default and forces the computer to go to "Hibernation Mode" if you shut down the computer. Perhaps you already know the hibernation mode from Windows™ XP/Vista/7. In Windows™ 8/10 it does not matter which way you use for computer shutdown. Even if you press the ATX power switch - with "Quickstart" active the computer goes to hibernation. If you restart from hibernation, an existing operating system boot menu is skipped and the computer starts always Windows™ 8/10. "Hibernation Mode" is an efficient way of power saving which uses other methods for hardware reinitialization. These methods are not supported by this driver version. Thus, whenever the computer comes back from hibernation, you will not be able to hear any sound from you soundcard. That's the reason why we currently cannot suggest to use any power management mode in Windows™ XP to Windows™ 10. For Windows™ 8/10 we recommend to deactivate the "Quickstart":
Control Panel | Hardware and Sound | Energy Options | Powerswitch behaviour | Settings for Shutdown | "Enable Quickstart": disable this option.
Good luck,
Jeroen Platenkamp
PostPosted: Sat Apr 23, 2016 4:22 pm
There seems to be a driver update for this now!
http://www.marian.de/en/downloads
