 Post subject: Restart without preset
PostPosted: Tue Sep 08, 2009 12:18 pm
Hi Hans? In Beta Version when computer restart and stereotool load? the Last preset don't load
PostPosted: Tue Sep 08, 2009 12:27 pm
Hi Boris,
A few questions:
- I assume you mean version 4.06 by "Beta version"?
- Is this problem new (didn't occur in version 4.05 and before)?
- By "the last preset doesn't load", do you mean that you're getting the wrong settings, or that the name isn't displayed in the Presets pull-down button?
Just to be sure: Did you restart without closing Stereo Tool first? The current settings are saved when Stereo Tool is closed or sent to the system tray, not every time when you change a setting (I tried that in the past, but it caused Stereo Tool to become very unresponsive.)
PostPosted: Tue Sep 08, 2009 12:36 pm
Yes i mean version 4.06 Beta. In version 4.05 i used my preset, and when i reload computer my last preset automatic load.In version 4.06 its not work
PostPosted: Tue Sep 08, 2009 1:33 pm
I've done some tests here but I couldn't reproduce it...
Which version are you using? Winamp, VST, stand alone?
Could you try it again? Say, just put Input volume to 10, reload Stereo Tool and see if the slider is still set to 10. If it reproduces I could send you a version with extra logging to see what's wrong.
PostPosted: Tue Sep 08, 2009 3:59 pm
I Using Standalone version, and used some modified Bojcha's preset with MPX Out and name My Preset, on version 4.05 i don't have problem with it.Today i want tested version 4.06. When comp. reload i listened silence. When i open Stereotool i see that My preset is not load. Any preset is not load, i manualy put my preset, and sound played....
