PostPosted: Mon Aug 31, 2015 3:29 am
Click to open, opens a blink of an eye and shuts down.
Since I installed/executed V7.73_64 for Linux. All previous versions are "contaminated".
Ubuntu 14.04 LTS.
PostPosted: Mon Aug 31, 2015 3:49 am
Can you run it on the command line in gdb?
So something like this:
gdb stereo_tool
run
and then paste the output here? Thanks...
After that, please try this:
1. Make a copy of the file in ~/.stereo_tool.rc
2. Delete the original
3. Try running Stereo Tool again. If it runs fine now, please send me the copied file (that's why I wanted you to copy it).
PostPosted: Mon Aug 31, 2015 12:31 pm
I not sure if this is what you want, I used Nemiver.
Disassembly:
0x000000000057c4d0 <>: cmpb $0x0,0x7a(%rsi)
0x000000000057c4d4 <>: jne 0x57d3cb
0x000000000057c4da <>: movb $0x1,0xdf(%rsp)
0x000000000057c4e2 <>: movb $0x0,0xcb(%rsp)
0x000000000057c4ea <>: xor %r12d,%r12d
0x000000000057c4ed <>: cmpb $0x0,0x79(%rsi)
0x000000000057c4f1 <>: jne 0x57ce4a
0x000000000057c4f7 <>: movb $0x1,0xd3(%rsp)
0x000000000057c4ff <>: movb $0x0,0x78(%rsp)
0x000000000057c504 <>: xor %r10d,%r10d
0x000000000057c507 <>: movb $0x0,0xa4(%rsp)
0x000000000057c50f <>: mov 0x8178(%rbp),%rcx
0x000000000057c516 <>: mov 0x8188(%rbp),%rax
0x000000000057c51d <>: mov 0x8180(%rbp),%rdx
0x000000000057c524 <>: mov 0xc(%rbp),%edi
0x000000000057c527 <>: xorps %xmm0,%xmm0
0x000000000057c52a <>: mov %edi,0xc(%rax)
0x000000000057c52d <>: mov %edi,0xc(%rdx)
0x000000000057c530 <>: mov %edi,0xc(%rcx)
0x000000000057c533 <>: movzbl 0x64(%rsi),%edi
0x000000000057c537 <>: mov %dil,0x1094(%rax)
0x000000000057c53e <>: mov %dil,0x1094(%rdx)
0x000000000057c545 <>: mov %dil,0x1094(%rcx)
0x000000000057c54c <>: mov 0x68(%rsi),%edi
0x000000000057c54f <>: mov %edi,0x1098(%rax)
0x000000000057c555 <>: mov %edi,0x1098(%rdx)
0x000000000057c55b <>: mov %edi,0x1098(%rcx)
0x000000000057c561 <>: movzbl 0x6c(%rsi),%edi
0x000000000057c565 <>: mov %dil,0x109c(%rax)
0x000000000057c56c <>: mov %dil,0x109c(%rdx)
0x000000000057c573 <>: mov %dil,0x109c(%rcx)
0x000000000057c57a <>: mov 0x70(%rsi),%edi
0x000000000057c57d <>: mov %edi,0x10a0(%rax)
0x000000000057c583 <>: mov %edi,0x10a0(%rdx)
0x000000000057c589 <>: mov %edi,0x10a0(%rcx)
0x000000000057c58f <>: movzbl 0x78(%rsi),%edi
0x000000000057c593 <>: maxss 0x74(%rsi),%xmm0
0x000000000057c598 <>: mov %dil,0x10a8(%rax)
0x000000000057c59f <>: mov %dil,0x10a8(%rdx)
0x000000000057c5a6 <>: mov %dil,0x10a8(%rcx)
0x000000000057c5ad <>: movss %xmm0,0x10a4(%rax)
0x000000000057c5b5 <>: movss %xmm0,0x10a4(%rdx)
0x000000000057c5bd <>: movss %xmm0,0x10a4(%rcx)
0x000000000057c5c5 <>: mov 0xc(%rsi),%edi
0x000000000057c5c8 <>: mov %edi,0xe4(%rax)
0x000000000057c5ce <>: mov %edi,0xe4(%rdx)
0x000000000057c5d4 <>: movss 0xd4(%rsp),%xmm0
0x000000000057c5dd <>: mov %edi,0xe4(%rcx)
0x000000000057c5e3 <>: mulss 0xf101bd(%rip),%xmm0 # 0x148c7a8
0x000000000057c5eb <>: mov 0x18(%rsi),%edi
0x000000000057c5ee <>: cmpb $0x0,0x6c(%rsi)
0x000000000057c5f2 <>: mov %edi,0xe8(%rax)
0x000000000057c5f8 <>: mov %edi,0xe8(%rdx)
0x000000000057c5fe <>: mov %edi,0xe8(%rcx)
0x000000000057c604 <>: cvttss2si %xmm0,%edi
0x000000000057c608 <>: movss 0xb4(%rsp),%xmm0
0x000000000057c611 <>: mov %edi,0xe0(%rax)
0x000000000057c617 <>: mov %edi,0xdc(%rax)
0x000000000057c61d <>: mov %edi,0xe0(%rdx)
0x000000000057c623 <>: mov %edi,0xdc(%rdx)
0x000000000057c629 <>: mov %edi,0xe0(%rcx)
0x000000000057c62f <>: mov %edi,0xdc(%rcx)
0x000000000057c635 <>: mov 0x24(%rsi),%edi
0x000000000057c638 <>: mov %edi,0xf8(%rax)
0x000000000057c63e <>: mov %edi,0xf8(%rdx)
0x000000000057c644 <>: mov %edi,0xf8(%rcx)
0x000000000057c64a <>: mov 0x24(%rsi),%edi
0x000000000057c64d <>: movss %xmm0,0x6b8(%rax)
0x000000000057c655 <>: movl $0x3f800000,0x6bc(%rax)
0x000000000057c65f <>: movss %xmm0,0x6b8(%rdx)
0x000000000057c667 <>: movl $0x3f800000,0x6bc(%rdx)
0x000000000057c671 <>: movss %xmm0,0x6b8(%rcx)
PostPosted: Mon Aug 31, 2015 12:53 pm
Hm, I had hoped for something more usable... So 0x000000000057c4d0 is the address of the crash?
PostPosted: Mon Aug 31, 2015 2:51 pm
I don't know. I have absolutely no knowledge regarding this... The fact that none of the previous versions is working is odd. Something went wrong in my system.
PostPosted: Mon Aug 31, 2015 8:16 pm
Do you have the correct version of jackd installed?
PostPosted: Mon Aug 31, 2015 11:15 pm
I suppose so. It's the same I used previously running ST, Rivendell, Mixbus, sometimes altogether for screencasting. I'm not aware of any updates affecting Jack... All my AV apps Jack dependent are running fine.
PostPosted: Tue Sep 01, 2015 12:04 am
Ow wait!
So before it worked fine?
So did you delete that .rc file??? Doing that basically removes any changes that Stereo Tool made.
PostPosted: Tue Sep 01, 2015 12:12 am
Yes, It the previous versions worked fine. Coincidence or not it stopped working after executing 7.73. All previous versions too.
I'm not at my pc at the moment... where should I find/create/delete that .rc file? I'm an almost complete nulity regarding those intricated matters :lol:
PostPosted: Tue Sep 01, 2015 1:05 am
Ah! Ok. Well, PLEASE make a backup first because something almost certainly has to be wrong in it, and if so, it would help me a lot if you can send it to me.
Ok. So where to find it? It's in your home directory, and it's called .stereo_tool.rc .
(The initial . makes it a hidden file so it could be that you don't see it immediately)
