 Post subject: SCA1 - Enable
PostPosted: Thu Aug 06, 2015 5:55 pm
Hey maybe this is a noob question and feel free to flame me.
But in the latest ST I can't find anywhere to turn up SCA1 and cant figure out how to feed it with vcable on the internal sound card.
Any help / steps would be appreciated.
 Post subject: Re: SCA1 - Enable
PostPosted: Thu Aug 06, 2015 11:00 pm
Are you in Extreme Tweaker mode? If not the settings will be hidden...
PostPosted: Sat Aug 08, 2015 9:51 pm
I wasn't but I am now. Still not seeing it output anything on the meter.
Yet Vcable shows output and i can output on the same vcable to a test stream.
PostPosted: Sun Aug 09, 2015 12:19 am
So what I'm not getting. Input signal to my SCA.
I do see an SCA pilot, but i don't see anything else.
Input is set, and when i tell it no sca, it does correctly route audio to the main encode.
Am i missing something here?
PostPosted: Sun Aug 09, 2015 10:29 pm
I am having 0 luck feeding the audio signal. I have a vcable feeding it. Tried mic, line, sp/dif feeds nothing. Yet the feeds will feed the primary channel just fine???
Anything I can check? I run RDS on this machine only through ST, and i can see the ST pilot, but that's it.
Its rather annoying.
PostPosted: Thu Aug 13, 2015 12:00 pm
Yep me too. I dont have any kind of carrier out from the mpx signal. I can't eve enable the sca 1 or sca 2 output.(They are grayed out ). :cry:
My radio station
http://amradio.ddns.net
PostPosted: Thu Aug 13, 2015 12:30 pm
Hm, ah... Are you using any of these features?
- Ignore high frequencies
- Synchronization between sound cards
Because those would disable SCA... That's something that needs to be fixed by the planned sound card redesign.
PostPosted: Fri Aug 14, 2015 8:29 pm
I guess along with SCA, sound card syncronization kills external RDS as well?
PostPosted: Sat Aug 15, 2015 1:37 am
Yes. The problem with sound card synchronization is that there can be too big differences in speed to compensate - and that would generate a bad (and not allowed) pilot.
