Not sure if it's a bug. I only use Stereo Tool for streaming. No FM or AM output is enabled. I discovered that in Normal Output under Signal Selection, even though it appears grayed out, the selector still functions and changes the output. I had it on Separate processing for streaming, but as a test, I switched it to Input without processing and the final output was actually raw, unprocessed audio. As I mentioned, I'm not sure that's a bug, but as the setting appears grayed out, I would think it's functionality would be ignored. Also, on the meters for output, they still behaved the same as though processing was happening, but I noticed the difference in the streamed audio and in my encoder display.
