 Post subject: Out of the blue
PostPosted: Tue Jun 16, 2015 9:38 pm
Blue is my favo color
I used nice gradients for the level bars
The only downside is that the limiting in the ACR stereo section is not realy visible because of the dark blue back groud i use in al the metering
@ Hans
Could it be possible in the futere to adjust more things in the GUI using Hex codes or something?
Could it be possible to use the same PNG files for the natural dynamics section ?
Download out of the blue.zip
Unzip into the main stereotool dir
Restart or start stereotool
Njoy
Out of the blue
download " out of the blue "
Test stream OGG
Test stream FLAC
 Post subject: Re: Out of the blue
PostPosted: Tue May 17, 2016 12:40 am
Nice skin
-- JE
.::.(())::. Urban Hitz Radio™ USA .::.(())::. The People' Choice for Hip-Hop & R&B!
Listen to Urban Hitz RadioGET A Local or TOLL-FREE Request Line NOW...Only $2 Monthly – StereoTool 7.24:Licensed!
PostPosted: Sun May 22, 2016 2:53 am
Nice one!
The filename for Natural Dynamics is: meter_expander.png
PostPosted: Sun May 22, 2016 3:12 am
Hm seems like you found that already - I downloaded it and ND is also blue!
