PostPosted: Thu Jun 11, 2015 12:02 am
Here at the largest Hindu Temple in the US (215 acres!), I thought I'd put Stereo Tool to work to ride levels in the main Prayer Hall. Music plays all day. Levels vary greatly.
I just don't know how to configure it to run after the output of my StudioLive 16.4.2 (which I normally run from the computer screen).
Thank you for your ideas and input!
PostPosted: Thu Jun 11, 2015 11:46 pm
Do you have the audio inside a computer, or is this a mixing table? I'm a bit confused about what StudioLive is after (quickly, I have to admit) looking at the website.
if you have it in a mixing table, you'll have to run Stereo Tool on a computer which accepts input from the mixing unit and outputs the result to the amplifier/speakers.
If you have it inside the computer, you will probably have to use a program like Virtual Audio Cable or VB Cable to send the audio from StudioLive into Stereo Tool.
