Post new topic  Reply to topic  [ 25 posts ]  Go to page 1 2 3 Next
 Post subject: MB2_V773
PostPosted: Sat May 23, 2015 2:46 pm
Hi all,
just want to share my for streaming and FM (maybe my final) made with ST V7.84
Settings (not free)
* Natural Dynamics (9 band) Credits for Bojcha
* Phase Rotation + phase delay
* AGC (3 band) (with or without matrix mode)
* Digi Multiband (5 band)
* Analog Multiband2 (9 band)
* Analog SB Limiter
* Advanced Clipper with Bass protection clipper
FM version Are availlable in 50µs + stokkemask and in 75µs (in progress)
[Genre] Hits
[Source] *.WAV
[Output] HD Stream + FM
Feedback would be great, thanks,
Gunther
MB2_V784_HD.sts [89.82 KiB]
Downloaded 804 times
MB2_V773_FM_75.sts [87.27 KiB]
Downloaded 652 times
MB2_V773_FM_50.sts [87.27 KiB]
Downloaded 719 times
 Post subject: Re: ARVFM HD/ FM preset
PostPosted: Thu May 28, 2015 3:11 pm
Very Nice, i"m using right now on my stream (without De-clippers and Nat Dynamics)
http://thepulsemontgomery.com
The Buzz - Central Alabama's Alternative Rock Station
http://thebuzzmontgomery.com
PostPosted: Sat May 30, 2015 8:37 pm
Sounds great :) good choice of music as well.
PostPosted: Tue Jun 02, 2015 2:06 pm
Thanks, i'm still doing overnight experiments with other presets, but i'm slowly tweaking yours here and there to fit the sound as needed.
I'm still having trouble with the S's when i stream over bluetooth in my car, i don't know if that's a stereotool thing, a wav file itself or just the radio in my cars.
PostPosted: Tue Jun 02, 2015 5:55 pm
Bluetooth encodes sound in a way that makes S sounds bad (and overall makes everything sound like bad reception on FM).
I put a cable in my car that I can plug into my phone when I want to listen to streaming audio, with Bluetooth I just cannot listen to it.
PostPosted: Tue Jun 02, 2015 6:31 pm
Yeah, i have an Aux/ USB port on a radio in one of my cars, i can plug my phone up to charge it, but to stream (Samsung Galaxy s3) i have to enable Bluetooth.
PostPosted: Thu Jun 04, 2015 5:15 pm
You can lower bandpass lowpass filter to 16Khz, because MP3 streams don't like HF very much, 18Khz is a little bit overkill I must say.
PostPosted: Thu Jun 04, 2015 5:22 pm
I'm Running 320KBPS .Wav's in stationplaylist, with my encoder set to 128Kbps
PostPosted: Thu Jun 04, 2015 5:29 pm
Yup the encoder can be in trouble when lowpass is set too high, this preset has a boost of HF and can cause distortion into 128Kbps.
You won't have spectacular difference when set to 16Khz, because you loose it anyway with lossless audio.
PostPosted: Tue Jun 30, 2015 4:55 pm
Updated STS file available in the first post,
Also a FM preset added
Enjoy,
Gunther
