PostPosted: Fri May 22, 2015 4:54 pm
Hello!
One question - is it possible to change RDS PS Text automatically, let's say from 4-8 pm? We are running station which is in the network that time and RDS need to be changed, but manually is just not an option. Airomate use Chronos scheduler to change text in RDS but in ST I don't get the idea how to change text on the fly.
Thanks.
Best regards!
PostPosted: Sun May 24, 2015 3:00 am
Well, there might be no ready made solution for this, but it could be scripted with something like Python. There could be a script running continuously, which has triggers based on time. Something like "if time is 12:00, write file ps.txt": "MID DAY!". Many possibilities here.
PostPosted: Mon May 25, 2015 10:01 pm
Thanx!
Now I'm just wondering if Hans will implement this function in the near future..
Regards!
PostPosted: Tue May 26, 2015 12:36 am
It would really be nice to have an easier way to schedule parameters (*any* parameters; some stations want less aggressive processing at night for example). I will add a note to the existing point on the todo list ( viewtopic.php?f=16&t=4985 ).
PostPosted: Tue May 26, 2015 7:45 pm
Thank you!
