 Post subject: regarding stereo tool
PostPosted: Fri Apr 03, 2015 7:12 pm
Hi, q question ! I have read this ( Intended for Winamp, SAM Broadcaster, Jazler, RadioBOSS, RadioDJ, MediaMonkey, AIMP
and other applications that support Winamp DSP plug-ins)
my question: works for another (Regie Automated) unprovided dsp plug-in? if yes how to do it. Thanks
PostPosted: Mon Apr 06, 2015 2:16 am
What do you mean exactly? What is Regie Automated? If a program supports DSP or VST plugins, use those. If it doesn't, you need to use VAC (Virtual Audio Cable) or VB Cable.
PostPosted: Tue Apr 07, 2015 6:22 am
hi , Thanks solved! (regie automation) is a software automation as sam broadcaster Jazler
