PostPosted: Sat Feb 07, 2015 7:51 pm
Hans,
The 7.51 VST plugin will show up properly, but the 7.60 will not work in Adobe Audition CS6.
I made a new VST directory, scanned/rescanned. It sees the dll, but it doesn't show in the VST options. Redownloaded the 751 dll and it begins working properly again.
Any thoughts?
PostPosted: Sat Feb 07, 2015 9:38 pm
Not really. Nothing really changed between those versions (wrt. VST). I switched to a new compiler for version 7.51 so if that would cause a problem then 7.51 should not have worked either.
Please tell me:
- Windows or Mac?
- 32 or 64 bits? And are you sure that you downloaded the correct one, the same as for 7.51?
PostPosted: Sun Feb 08, 2015 3:57 pm
Windows, 64 Bit OS, but Adobe uses 32 Bit Plugins...
If I remove all but 7.60, there is no plugin available. If I put 7.51 back in, it's fine. I actually tried both of them to make sure I wasn't losing my mind with the same result...
