 Post subject: SSE - Not Install
PostPosted: Sun Jul 26, 2009 3:13 am
The programa not install no way. alway shows the not my computer, a amd sempron LE not support SSE, how can install?
 Post subject: Re: SSE - Not Install
PostPosted: Sun Jul 26, 2009 12:01 pm
If your computer doesn't support SSE2, you should still be able to install Stereo Tool - you'll just get a less-optimized version.
Please tell me:
- Which Stereo Tool you try to install (eg. Winamp, Stand alone, VST)
- What happens exactly (error message?)
PostPosted: Sun Jul 26, 2009 5:17 pm
Please tell me:
i too have the same AMD sempron processor , i tried to install v4.04 plugin for winamp, here is a snaphot
PostPosted: Sat Aug 08, 2009 3:42 am
Oops - you said SSE, not SSE2...
(Sorry for the delayed reply, I was on holiday)
Do you know if your processor does support SSE (2)? If it does, the installer doesn't detect it properly. If it doesn't, chances are that your PC is so slow that Stereo Tool won't run properly anyway (in that case, can you tell me the CPU speed?).
SSE was introduced back in 1999, so unless your PC is VERY old, there's probably a problem with the detection....
PostPosted: Thu Aug 27, 2009 6:08 am
Yes, my computer is a Sempron LE1200 and haves SSE, SSE2 and SSE3, but the program no detect it.
PostPosted: Sat Aug 29, 2009 11:53 pm
I've rewritten some parts of the installer, can you check if it works now?
If not, it now shows how it detects your CPU, could you send me that text if installing fails?
Thanks.
http://www.stereotool.com/download/dsp_ ... r_BETA.exe
