PostPosted: Fri Jan 30, 2015 4:19 am
This is a version of Preset KnockOut, but for a Free Version ST.
I think I have disabled all payments Filters, if I left any activated by mistake, please let me know.
Any comments may do so freely. ;)
GAP_KnockOut_Free_Edition_v0.1.sts [67.67 KiB]
Downloaded 605 times
by GAP
"Less is More" (Bob Katz)
PostPosted: Sun Feb 01, 2015 11:30 am
Thank you sir!
PostPosted: Wed Feb 04, 2015 7:02 pm
Advanced Clipper still enabled. I've disabled the advanced clipper and lot a spikes over 0 db are there, I just down the post amplifier level to 64% (-3.88 dB) and the peaks are gone at the decoded side of my stream but not in the Vumeter levels in StereoTool (strange). Im not using attenuation in the edcast or output in StereoTool neither. Attach the mod version by me.Image
GAP_KnockOut_Free_Edition_v0.1.sts [67.43 KiB]
Downloaded 452 times
PostPosted: Thu Feb 05, 2015 4:18 am
Feeling Thank you for your feedback.
Here 'a new version, which I turned off the Advance Clipper and have replaced this by Simple Clipper and Single Band Compressor(used as a limiter).
I think that the peaks are now properly controlled, you can try and tell me you think? Thank You! ;)
GAP_KnockOut_Free_Edition_v0.2.sts [68.73 KiB]
Downloaded 525 times
by GAP
PostPosted: Sat Feb 07, 2015 5:54 pm
Nice!!! BTW I made just a few changes to feet the needs of my aac+ stream. http://23.29.123.98:8430/stream
GAP_KnockOut_Free_Edition_v0.2 mod_by_Feeling.sts [67.44 KiB]
Downloaded 521 times
PostPosted: Mon Feb 09, 2015 8:43 pm
Really good! Good presence and very clean! :D :shock:
by GAP
PostPosted: Sun Mar 01, 2015 5:26 am
In this version I changed the behavior of SingleBand Compressor primarily to make the sound more open and louder at a time. :shock:
You should try it and tell me ... :)
GAP_KnockOut_Free_Edition_v0.3.sts [68.73 KiB]
Downloaded 587 times
by GAP
PostPosted: Sun Mar 01, 2015 9:45 pm
Sounds great !
PostPosted: Tue Mar 03, 2015 1:39 pm
Sounds great !
Thanks ;)
by GAP
PostPosted: Wed Mar 04, 2015 1:46 am
Testing in my stream!!!
