Hey guys, I am new here, I went to the net searching for a software which will work together with my touchscreen jukebox software, I am trying out 2 of them right now:
http://www.albumplayer.com/
http://www.freeboxjukebox.com/
The problem I am facing is that I have some mp3's which come on much louder than others so I have to constantly manually adjust the EQ's frequencies, all of my mp3's have been run through mp3gain so the volume itself is pretty much consistent but some mp3's it is the bass, then for others it's the highs and others the mids. When I play music through any software on my home stereo is is not so much of an issue but when I bang out music on my large rig this is where it becomes important so I don't blow my speakers. I joined a couple of broadcasting forums yesterday asking just what it is FM radio stations use to have all frequencies of all tunes constant and was told this:
It is compression that does that, radio stations typically use a multiband compressor that compresses several frequency ranges indivually. This can be a special hardware box, or it can be done in software with Breakaway being one of the better software multiband compressors. By compressing different ranges of audio individually, it's like custom adjusting the EQ for each song.
One catch with this is the newer digital multiband compressors do add a bit of latency or delay to the audio. If you're listening to that in headphones while talking on a mic, it will mess with your brain and you'll find it difficult to speak properly.
So Stereo Tool was recommended and is the reason I am here, I would like to know if I can work this software with my jukebox software and also if you guys experience any latency issues with Stereo tool please?
