Post new topic  Reply to topic  [ 20 posts ]  Go to page 1 2 Next
 Post subject: Diggy Down
PostPosted: Tue Jan 13, 2015 9:02 pm
Heya..
New preset from me!
This time i wanted to minimally use Clipper, maybe even (if possible) to fully disable it. 99% of final job is done by Singleband limiter.
Preset is maximally open by yet still much processing is behind MB.
Let me know!
Diggy-Down_v15c.sts [67.54 KiB]
Downloaded 1325 times
Ok here is almost final version, might be few tweaks for final.
Diggy-Down_v020_Streaming.sts [87.14 KiB]
Downloaded 714 times
Soon i will also update for FM version wich will be just bit louder.
(beta47)
Fix for beta48-50
Diggy-Down_v023_Streaming.sts [87.24 KiB]
Downloaded 765 times
note: preset relies much on NaturalDynamics and DeClipper. So it best works as-is.
Beta29 - bit less into final clip and new 2-bands xover in MB2. Streaming version, FM version will follow later. More stronger/tighter bass.
Diggy-Down_v029_Streaming.sts [87.12 KiB]
Downloaded 943 times
Final Version in StereoTool v7.70+
B^^
 Post subject: Re: Diggy Down
PostPosted: Wed Jan 14, 2015 1:15 pm
Excellent preset Bojcha. One of the first presets where I hardly get that restless or 'jumpy' feeling I usually get with Stereotool.
Still trying to figure out how to better get control over that restless sound but this preset could be a good way to start.
Edit: The only thing I switched off is the Natural Dynamics section. It does bring punch on one hand but also enhances that restless sound
PostPosted: Wed Jan 14, 2015 10:05 pm
Rhodes,
What do you mean with that? I am really curious :mrgreen:
PostPosted: Thu Jan 15, 2015 10:29 am
Hi Edgar,
When it comes to audio/sound I always find it hard to describe but I am going to give it a try anyway. It is basically exactly what I described: The overal sound is somewhat nervous, expecially with slower attack/release times. Sometimes it might take up a few days before something starts to irritate. I have to say though that with all the (new) coupling options I seem to get/have better control. Better overal consistancy.
PostPosted: Fri Jan 16, 2015 2:39 pm
Wow... What a nice preset, the bass is incredible. :o
PostPosted: Fri Jan 16, 2015 8:52 pm
Thanks..
Was affraid that there is not enough bass. I anyway rised it a bit and also improved a bit transients in limiter vs clipper.
Next update later..
PostPosted: Sat Jan 17, 2015 12:09 am
As per the other post Bojcha change my preset to this
Check it out please
if stream title is diggy down its live
Thanks
Matt
https://centovacast.galaxywebsolutions. ... onukradio/
PostPosted: Sat Jan 17, 2015 3:32 am
hey Matt. Sound ok to me :)
Levels are also ok. I guess tracks you play are mostly mp3?
PostPosted: Sat Jan 17, 2015 5:21 am
For what type of music is this preset most suited for?
PostPosted: Sat Jan 17, 2015 9:45 am
Hi
Yes mainly Mp3 but some other, we play all genres this is just a test stream
I am very happy with this setting seems to sound good on all genres which is the only thing I have found hard with Stereotool
I moved from breakaway and used rustonium on that
Thanks Again
