PostPosted: Tue Jan 13, 2015 3:55 pm
You've come a long way since V1.0 Hans! Congratulations with the new version!
Do you still have a screenshot of V1.0 or V1.1 somewhere? :)
PostPosted: Tue Jan 13, 2015 7:20 pm
I even still have the DLL somewhere, I'll post it here when i get home to scare everyone :)
PostPosted: Tue Jan 13, 2015 9:49 pm
Version 1.12 (same as 1.0 but with a few bug fixes mainly for hangups). Winamp plugin. Enjoy!
http://www.stereotool.com/download/dsp_ ... ol_112.dll
PostPosted: Wed Jan 14, 2015 10:26 am
Nice one. :-)
I only got noise under Winamp 6 but it does work with Winamp 2.91. It is actually better than I expected it to be. I like the way the single band compressor reacts.
PostPosted: Wed Jan 14, 2015 1:32 pm
It might surprise you but all these features are still in there in the latest version (it should even keep the settings if you switch between the two versions): Classic Multiband is this multiband with 2 extra bands for the bass added (and that's the reason why in the .sts file the first two bands have band numbers -1 and 0); Classic Singleband is the singleband compressor, and the stereo part is Stereo Image in version 7.60.
PostPosted: Wed Jan 14, 2015 7:18 pm
A bit of a shock to see the old GUI again. :shock: It feels so long ago!
PostPosted: Fri Feb 13, 2015 11:00 pm
I still use version 2.10 every day (I also have a fully paid up version 7 on another PC running 24 hours)
Its great if you have a low spec pc (I used to run it on a Samsung Nc110 netbook with no problems) and you can get it to sound pretty good if you take some time and make careful adjustments. Its a really good piece of software even now.
PostPosted: Sat Feb 14, 2015 1:52 am
Newer versions (especially 7.51 and 7.60) should really use a lot less CPU power than version 2.10, if you use the same options. Probably less than half!
PostPosted: Sun Feb 15, 2015 5:30 am
Stereo Tool (a.k.a. Radio Tool) has come along way.
Not scary at all. Primitive as heck best describes it. Like when dinosaurs walked the Earth. It's something I would of never touched 10 years ago and now I find uses for it all the time.
PostPosted: Fri Feb 27, 2015 8:55 pm
Brings back great memories! What a great ride it's been so far...
Great Hits and More!
http://RadioDAVE.US
