 Post subject: Presets
PostPosted: Fri Jul 10, 2009 1:03 pm
Who have some presets for me?
I used the ones are included in stereo tool, they sound well, but I like to try some presets from other stereo tool users.
So if you have some good presets, post them here.
I really like to test them. (you can upload them by use for example speedyshare.com or send me some preset using the mail: karlvos@hotmail.com)
Thanks,
Karl Vos from the Netherlands
 Post subject: Re: Presets
PostPosted: Fri Jul 10, 2009 5:48 pm
will be good to tell us what kind of sound you like, do you use it for home use or transmitter... etc
PostPosted: Fri Jul 10, 2009 8:28 pm
I use it for FM broadcasting, and my sort of music is pirate music
Here some youtube movies if you dont know what pirate music is:
http://www.youtube.com/watch?v=SekfD8sjsyI
http://www.youtube.com/watch?v=lRtyTuJd ... re=related
http://www.youtube.com/watch?v=nvjoSpt3fRc
Thanks in advance,
PostPosted: Fri Jul 10, 2009 8:59 pm
If you're broadcasting old music with a lot of hiss, increasing the value of the noise gate might improve the sound a bit.
And if you're broadcasting from vinyl records (LP's), if you hear any rumble in the sound you can increase the highpass filter (under "bandpass") a bit.
This type of music _very_ remotely resembles what Q-Music broadcasts in the morning during "Het Foute Uur". During that hour they use the most aggressive compression that I've ever heard. I'm not saying that that's good, but I guess they did research a bit what listeners like...
On the other hand, when zapping through the FM band I've often heard pirate radio stations that broadcast music like this that sound extremely clear (almost CD-quality) because they use almost no compression at all. So that might also be an idea: Lower the top 2 sliders (soft volume) in the Pre Limiter a bit, and then increase Loudness (if needed).
PostPosted: Sat Jul 11, 2009 3:10 pm
thanks,
I've done wat you said, and here is a upload of my new preset:
http://www.speedyshare.com/973481835.html
So i've you would like to take a look and maby you would test it for me?
I do also like a bit more bass, i've done that whit de equalizer, but i dont think this is the best way to get some more basses?
thanks in advance!
and if somebody have some good presets, mail me or upload them (see my earlier post)
I really like to test some!
