PostPosted: Sat Jan 10, 2015 7:58 am
The multiband bands cross at a wrong place in the GUI (maybe also in actual audio processing, I don't know).
Issue started with 7.51 and is still there in 7.60.
Reproduction: factory reset -> set multiband bands number to 2 and frequencies to 100 Hz and 10000 Hz -> spot bands crossing at about 1111 Hz instead of the correct 1000 Hz
Note: above settings are just an example for easy spotting; issue happens no matter what, especially with any number of bands at any frequency;
PostPosted: Sat Jan 10, 2015 10:33 pm
True. And a simpler thing to test: If you set 3 bands to 900, 1000 and 1100, the center band peak is shown around 1100 instead of 1000.
Woops! Audio is also at 1100... That's not good!
