 Post subject: ST Skin Change
PostPosted: Fri Dec 19, 2014 11:45 pm
Hi. Is it possible to change the Skin in ST (mainly colors )?
My radio station
http://amradio.ddns.net
 Post subject: Re: ST Skin Change
PostPosted: Fri Dec 19, 2014 11:54 pm
Yes. You need a file that I've posted in several forum threads called 'skin.zip'. Put it in the same directory as Stereo Tool, then just open and edit all the files (they are .png files).
Found it:
http://www.stereotool.com/download/SKIN.zip
PostPosted: Sat Dec 20, 2014 8:24 am
Thank you very much Hans but i am having trouble with it. First problem is that when i copy into the ST's it doesn't run and it crashes immediately after i start it. Secondly when I delete some files it runs but it seems to run like i switched the 16bit mode on....
Thank you very much
My radio station
PostPosted: Mon Dec 29, 2014 10:08 pm
Confirmed. Will check what's wrong.
PostPosted: Mon Dec 29, 2014 10:15 pm
Found it! Remove the file font_small.png. It contains the wrong number of characters which causes problems. Without this file it runs fine.
However, this skin is different from the currently active skin - it must be a really old file. I'll create a new one now.
PostPosted: Mon Dec 29, 2014 10:18 pm
Current skin attached!
SKIN_20141229.zip [193.6 KiB]
Downloaded 607 times
PostPosted: Tue Dec 30, 2014 5:26 pm
Thanks Hans.
One thing that i am having problem with is the meters in ND, Stereo Image and the Waveform Display (mainly the declipper detection).
My radio station
PostPosted: Tue Dec 30, 2014 5:53 pm
The waveforms cannot be skinned at this moment.
I think the ND and Stereo Image aren't skinned in this skin (it uses an internal default), the file names that you need are:
Just copy one of the other meter png files.
PostPosted: Tue Dec 30, 2014 6:35 pm
Thanks again Hans
Can you please tell me what the image names are for the meter in the fm levels, modulation power
Edit : Where i should post my meter skin???
My radio station
PostPosted: Wed Dec 31, 2014 4:52 am
Complete list of images (please ignore the paths):
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_on", bitmap_widgetOn, true, false, true);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_on_b", bitmap_widgetOnB, true, false, true);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_off", bitmap_widgetOff, true, false, true);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_off_b", bitmap_widgetOffB, true, false, true);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_on_2", bitmap_widgetOn2, true, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_on_2_b", bitmap_widgetOn2B, true, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_off_2", bitmap_widgetOff2, true, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_off_2_b", bitmap_widgetOff2B, true, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_panel2", bitmap_widgetPanel2, false, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_button", bitmap_widgetButton, true, true, true);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "bg_small", bitmap_bg, false, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "bg_container", bitmap_bgContainer, false, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "bg_containerheader", bitmap_bgContainerHeader, false, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "bg_containerbottom", bitmap_bgContainerBottom, true, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "bg_containerbottomheader", bitmap_bgContainerBottomHeader, true, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "slidernoteditable", bitmap_sliderNotEditable, false, false, true);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "sliderbar", bitmap_sliderBar, true, true, true);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "sliderback", bitmap_sliderBack, true, true, true);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "subselection_container", bitmap_subSelectionContainer, false, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "subselection_selected", bitmap_subSelection_Selected, true, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "subselection_notselected", bitmap_subSelection_NotSelected, true, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "subselection_headerselected", bitmap_subSelection_HeaderSelected, false, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "subselection_headernotselected", bitmap_subSelection_HeaderNotSelected, true, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "settings_container", bitmap_settingsContainer, false, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_enumPulldown", bitmap_widgetEnumPulldown, true, true, true);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_enumPulldownDescr", bitmap_widgetEnumPulldownDescr, true, true, true);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_enumPulldownArrow", bitmap_widgetEnumPulldownArrow, true, true, true);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_enumValue", bitmap_widgetEnumValue, true, true, true);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_presetValue", bitmap_widgetPresetValue, true, true, true);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_mini", bitmap_widgetMini, true, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_miniSlider", bitmap_widgetMiniSlider, true, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "scrollbar", bitmap_scrollbar, true, true, true);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "scrollbarBar", bitmap_scrollbarBar, true, true, true);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_bottomSwitch", bitmap_widgetBottomSwitch, true, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_meterHorizontal", bitmap_widgetMeterHorizontal, false, false, true);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_meterVertical", bitmap_widgetMeterVertical, false, false, true);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_rds", bitmap_widgetRds, false, false, true);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_rdsInner", bitmap_widgetRdsInner, false, false, true);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "widget_buttonBig", bitmap_widgetButtonBig, true, false, true);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "icon_warning", bitmap_iconWarning, false, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "infoWindow", bitmap_infoWindow, false, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "warningWindow", bitmap_warningWindow, false, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "warningWindowOk", bitmap_warningWindowOk, false, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "warningWindowCheckboxOn", bitmap_warningWindowCheckboxOn, false, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "warningWindowCheckboxOff", bitmap_warningWindowCheckboxOff, false, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "icon_info", bitmap_iconInfo, false, false, false);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "icon_50us", bitmap_icon50us, false, false, true);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "icon_75us", bitmap_icon75us, false, false, true);
    loadPngs("C:\\share\\wav\\mp4\\button4\\", "icon_stereo", bitmap_iconStereo, false, false, true);
    loadPngColors("C:\\share\\wav\\mp4\\button4\\", "meter_volume", COLOR_VOLUME);
    loadPngColors("C:\\share\\wav\\mp4\\button4\\", "meter_volume2", COLOR_VOLUME2);
    loadPngColors("C:\\share\\wav\\mp4\\button4\\", "meter_volumeRed", COLOR_VOLUMERED);
    loadPngColors("C:\\share\\wav\\mp4\\button4\\", "meter_declipper", COLOR_DECLIPPER);
    loadPngColors("C:\\share\\wav\\mp4\\button4\\", "meter_noiseGate", COLOR_NOISEGATE);
    loadPngColors("C:\\share\\wav\\mp4\\button4\\", "meter_stereoBoost", COLOR_STEREOBOOST);
    loadPngColors("C:\\share\\wav\\mp4\\button4\\", "meter_stereoImage", COLOR_STEREOIMAGE);
    loadPngColors("C:\\share\\wav\\mp4\\button4\\", "meter_agc", COLOR_AGC);
    loadPngColors("C:\\share\\wav\\mp4\\button4\\", "meter_agcGate", COLOR_AGC_GATE);
    loadPngColors("C:\\share\\wav\\mp4\\button4\\", "meter_compressor", COLOR_COMPRESSOR1);
    loadPngColors("C:\\share\\wav\\mp4\\button4\\", "meter_compressor2", COLOR_COMPRESSOR2);
    loadPngColors("C:\\share\\wav\\mp4\\button4\\", "meter_expander", COLOR_EXPANDER);
    loadPngColors("C:\\share\\wav\\mp4\\button4\\", "meter_bassBoost", COLOR_BASSBOOST);
    loadPngColors("C:\\share\\wav\\mp4\\button4\\", "meter_clipper", COLOR_CLIPPER);
    loadPngColors("C:\\share\\wav\\mp4\\button4\\", "meter_bassClipper", COLOR_BASSCLIP);
    loadPngColors("C:\\share\\wav\\mp4\\button4\\", "meter_deesser", COLOR_DEESSER);
    loadPngColors("C:\\share\\wav\\mp4\\button4\\", "meter_mpx", COLOR_MPX);
    loadPngFont("C:\\share\\wav\\mp4\\button4\\", "font-small", fontSmall);
I've just made a new forum for skins: viewforum.php?f=24
Tomorrow I'll move this thread there.
