 Post subject: 4.02
PostPosted: Sat Jun 20, 2009 3:37 am
ive never had this problem before but sometimes it goofs up and the grey background and some of the options magically disappear. v4.02
(yes i blacked out my playlist)
 Post subject: Re: 4.02
PostPosted: Mon Jun 22, 2009 12:51 am
I think I've solved it.
Basically, for some reason Windows did notify my application that it had to clean the window background (which makes it the default window color, usually light gray) - but then it didn't tell me to redraw the content. So now, when I'm getting a "clean background" notification, I'm sending a redraw notification to myself... :roll:
Anyway, this seems to work, and in the process I've been able to remove some unnecessary redrawing that I had added in the past as a workaround for this problem (at the time I didn't really know what the problem was). This reduces the flickering which occurs when dragging another window over the Stereo Tool window, or when the Stereo Tool window is moved into the screen.
Command line: http://www.stereotool.com/download/ster ... d_BETA.exe
This version is still tagged as 4.02, but this new redrawing behavior will be available later in version 4.03. Note that there's also a change to the audio processing w.r.t. version 4.02.
PostPosted: Tue Jun 23, 2009 2:40 am
I noticed that there was a new situation where the image went light gray, caused by the changes I made to reduce flickering... Should be solved now too.
