Hi,Hans I wanted to ask Use as directed automatic sam and Rds Txt do this:
HTML will do this. You do not need a PAL script at all. Make an HTML Input file with the following in it:
$song.combine$
Call that file something like "_rds.html"
Put it in your HTML INPUT (Config > HTML...)
Set your HTML output file to be something like "rds.txt"
Make sure you add that to the upper section on the HTML Output page. Have SAM auto-update it on song change.
From here, it's up to YOU to get that 'rds.txt' output file to your transmitter/rds encoder. I would suggest via FTP, or if you have a direct network connection to your RDS encoder, have it find that rds.txt file in the place you have SAM putting it.
This file will automatically change with EACH song change, thus updating your RDS with the current Artist/Title
you wonder if it is possible to Artist and song only 3 times Fixed radio name change until the next song
Thanks
