 Post subject: My first preset
PostPosted: Mon Sep 01, 2014 4:53 pm
Based on a Bojcha's preset.
Extremely fast AGC, presence is the main aim.
Couldn't avoid the contamination of the DC beep on the overall sound when it plays (wich is common to most of the presets available)
FAst&fast.sts [65.02 KiB]
Downloaded 413 times
 Post subject: Re: My first preset
PostPosted: Tue Sep 02, 2014 5:26 am
What is "contamination of the DC beep"?
PostPosted: Tue Sep 02, 2014 1:16 pm
When the declipper *beep* beeps (unregistered versions), or a short single tone bursts on the audio in feed, it shuffles the eq. on the sound, mainly if the overall audio is low. Version 7.51. Of course this is an extreme occurrence.
PostPosted: Tue Sep 02, 2014 4:24 pm
Just to disable the declipper option and the beep will gone, but the declipper does not works ;)
