 Post subject: CRASH DSP plugin
PostPosted: Wed Apr 09, 2014 7:19 pm
SAM Broadcaster crashes immediately with Stereo Tool (DSP plugin) since the last windows patch day (Windows7 64-bit) :shock:
Pics attached.
Please fix it, thank you !
 Post subject: Re: CRASH DSP plugin
PostPosted: Thu Apr 10, 2014 4:32 am
Which Stereo Tool version are you using?
PostPosted: Thu Apr 10, 2014 6:50 am
Stereo Tool 7.30
I wrote a batchfile already that :arrow: moves the dll outta the SAM plugins before SAM starts and after SAM starts succesfully the batch :arrow: moves the dll back into the plugin folder.
That works and SAM runs without any prob with Stereo Tool. But this cannot be the solution of course...
Thank you for your support.
8-)
PostPosted: Thu Apr 10, 2014 9:51 am
Hm.... This is really weird. I know that SAM does some things that differ from how other programs that support DSP plugins do things (there have been issues with SAM before that didn't occur anywhere else). In this case it seems that it has something to do with the detection of the DLL, if you can run it after moving it as you said.
Could you try what the latest beta version does? viewtopic.php?f=14&t=5508&start=69
PostPosted: Thu Apr 10, 2014 4:45 pm
Version 7.41 works with SAM without any crash at start. :P
Secrets of the sea .... (Jaques Cousteau)
Thank you for your support - pity, now i don't need my bachtfile anymore (j/k)
:mrgreen:
