 Post subject: ASIO Channel
PostPosted: Tue Apr 28, 2009 9:44 am
Please prompt, what channel in ASIO is the best to use on Input and Output configuration? IN-4,5. OUT-2,3 is normal or no?
Sorry about my english. I am from Ukraine,friends tell me about stereotool, and i begin tested stand alone demo on FM broadcast.
Yesterday i test the FM Soft preset and sound is get realy better .
 Post subject: Re: ASIO Channel
PostPosted: Tue Apr 28, 2009 11:48 am
if you get sound in that configuration .. then it's ok.
PostPosted: Tue Apr 28, 2009 12:55 pm
Thanks ! And i want to know what diferents have asio channel?
PostPosted: Tue Apr 28, 2009 1:26 pm
Say your sound card has 6 output channels. Then this is how you choose what you send to which channel, for example channel 1+2 = FM output, 3+4 = normal output, etc.
Some sound card treat channels differently. For example, if you have an ESI Juli@ sound card, channels 1+2 are analog 192 kHz channels, and 3+4 are digital 96 kHz channels. In that case you HAVE to use 1 and/or 2 for FM output, because otherwise part of the stereo and the RDS info is lost. For details like this, check your sound card documentation (usually all channels are the same though).
