Doin some tests with it. Might have an update monday or tuesday…
EDIT:
Went back to the drawingboard and re did everything.
The preset mimics the compression work done by Prism, what it dosnt mimic is the expansion. Thats because its is unique to the way Prism works. Well, everything is unique to how Prism works.
I did 3 versions of it; acually total redone, nothing in common with v1;
v1.1 Gentle AGC. A tiny Advanced on top to level the peaks a bit.
v.1.11 with a tad more AGC for more gain riding. Sounds dull to me. But hey…I like the hardcore NY sound that once was…
v.1.1-woutAGC is with same as 1.1 but out … AGC. Just the compression and a few other stuff.
The presents are not "brick wall" limited.
Since Prism almost never stood alone, some used levelers infront for gain riding, and most used 8100 on the end. Some even used a Dominator between Prism and 8100 to get it tighter.
What would be fun, is if someone got their hands on a working 8100 and could feed from ST and record the output from FM. Giving the 8100 like a 6db gain reduction. My old 8100 died…but I still have a XT2 thats been used maybe 20 minutes (hooked it up once, did'nt like it, took it down again).
Feed the preset so that you have a 6db headroom on the input meter (so that the limiting on ST input dont go into effect). The output is low. Crankit up to what you like, but look out for overshots…
theres no hardlimit on the end.
(also I've had some problems with the highest freq getting reset when loading the preset. The band should read 64Hz, 362Hz, 2040Hz and 11.7 kHz.)
Oh yeah, have fun
MrDonT
